Something Missing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dozer711, Oct 7, 2018.
  1. Oct 7, 2018 at 6:44 PM
    #81
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Lame. I've used them for 14 years now in my 05 though my 18. I always have tie downs in there and usually a couple slobbery tennis balls for my lab. Ridiculous they change it after that many years for no other reason than being cheap.
  2. Oct 7, 2018 at 6:47 PM
    #82
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I didn’t realize there was a front rail in the beds. I’ll have to look into that. At least I have the cubbies and side rails with cleats
  3. Oct 7, 2018 at 6:55 PM
    #83
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    May have to give this another go. Bought a Remedy 7 last year, rode it once, just couldnt get into it, like I thought I would.
  4. Oct 7, 2018 at 7:04 PM
    #84
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    Bummer, I have mine filled with ropes, bungees and other random stiff. In my opinion there is no such thing as too much storage. If its unused wasted space why not make it so you can put crap in it?
  5. Oct 7, 2018 at 7:05 PM
    #85
    Tacoma1818
    Tacoma1818 Well-Known Member
    Man I didn’t get these. Must remove them for factory tonneau?
  6. Oct 7, 2018 at 7:08 PM
    #86
    TacoBuffet
    AL
    Dealer owes you then. Unless they quit including them on 18's which would be a load of sh*t from Toyota.
    oconnor and shakerhood like this.
  7. Oct 7, 2018 at 7:14 PM
    #87
    Junior314
    Junior314 Well-Known Member
    Northeast
    '17 MGM OR DC/SB
    Cosmetic.
    Am I missing something here?
    I keep straps and bungies in there and maybe its just me but I don't notice any issues with dirt/grime/water in that compartment.
  8. Oct 7, 2018 at 7:21 PM
    #88
    Fearthisbeard
    Josh
    Gilbert AZ
    Taco
    My 2018 has them
    oconnor likes this.
  9. Oct 7, 2018 at 7:22 PM
    #89
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Same here
    Thegenerik1 and shakerhood like this.
  10. Oct 7, 2018 at 7:50 PM
    #90
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Ratchet straps in mine...
    What's odd to me is Toyota had to spend $$$ to change tooling to make the bed side without the cubby. Sure they save cash in the long run, but it's like spending a dollar to save a nickel. Pretty typical between finance and engineering (I'm on the r&d side in a different industry and same things).
    oconnor and tonered like this.
  11. Oct 7, 2018 at 7:52 PM
    #91
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    It's an option on the third gen. Amazon frequently has them for like $60 and it's just a few bolts to install.
  12. Oct 7, 2018 at 7:54 PM
    #92
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Honestly removing a hole like this is a simple change and if it's cut out instead of cast into the bed, it's a big savings. Either way, it's a dollar now to save like a quarter a year which, over the course of the next 7-8 years the third gen will take, is significant.
    Personally, I still feel like Toyota is starting to nickel and dime across the board and it's going to start to hurt them.
    Kooltaco, Biscuits and shakerhood like this.
  13. Oct 7, 2018 at 8:17 PM
    #93
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The front rail is not an option, it does not come on any 3rd Gen, fortunately you can buy one for a 2nd Gen and bolt it right up!
    tcjacado, tonered and Thegenerik1 like this.
  14. Oct 7, 2018 at 8:42 PM
    #94
    baldbeardedtaco
    FL
    Any drilling required or straight bolt on? How do most make use for the front rail, just trying to see if I’d utilize this
  15. Oct 7, 2018 at 8:45 PM
    #95
    shakerhood
    Southern Ohio
    It is a straight bolt on, I swapped mine over from the old 2015. The cleats slide in so you can use them for tie downs as I do, also have seen some bike mounts fit in the rail too.
  16. Oct 7, 2018 at 8:53 PM
    #96
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Looks like in addition to the left cubby being gone the front rail is gone too.
  17. Oct 7, 2018 at 9:12 PM
    #97
    shakerhood
    Southern Ohio
    Front rail disappeared after 2015...
    tcjacado, tonered and TACOVRD[QUOTED] like this.
  18. Oct 7, 2018 at 10:37 PM
    #98
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    My 2018 has the cubbies and I use them all the time.
    doublethebass and shakerhood like this.
  19. Oct 7, 2018 at 11:04 PM
    #99
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    I have my compressor in there and it's awesome. Bummer.
    Biscuits and batacoma like this.
  20. Oct 7, 2018 at 11:18 PM
    #100
    SCJeffro
    SCJeffro @Voodoo_Blu_Taco
    2021 Voodoo Blue TRD Sport
    I had the compartment on My 2015 prerunner. I used it all the time.
