Something on my glass that won't come off
Discussion in 'Detailing' started by Juggernaut, Feb 5, 2012.
  1. Feb 5, 2012 at 10:14 PM
    Juggernaut
    Juggernaut [OP] Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    It looks as if the lower part of my windshield is fogged up, but I can't wipe it or clean it off. Ive soaked both sides of the glass with windex to no avail. My truck was at a body shop a couple weeks ago, so I think this "dirt" is from them. Any advice on some super strong cleaner to remove this stuff?
  2. Feb 5, 2012 at 10:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Use a new single edge razor blade. images_3b70222e01efd1ecf0ce3685b81d19c3556a545d.jpg
  3. Feb 6, 2012 at 5:54 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    It might be overspray. What does it feel like? Gritty or smooth?
    I agree; a blade is a good thing to try.
  4. Feb 6, 2012 at 6:23 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    goo gone and a rag / follow up with some alcohol or windex
  5. Feb 6, 2012 at 6:25 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Also Steel wool is great for removing overspray from glass and will not scratch your glass.
  6. Feb 6, 2012 at 7:03 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I would be careful on the Windshield, there is a film on each side of the glass on the windshield that keeps it from breaking into a million pieces in an accident. I actually scratched mine on the outside alittle wiping off dried birdshit with a wet rag believe it or not. I would actually be hesitant to use steel wool. I would try a mild paint thinner because it sounds like over spray. The razor blade would work too as long as its a flat surface and be very careful not to dig into it. Good luck, with whatever you use.
  7. Feb 6, 2012 at 8:44 AM
    A_Ninja_Racer
    Tampa, FL
    I hate hearing this there is nothing wrong with using steal wool on automotive glass. Car detailers and body shops use it all day every day. It is one of the best ways to clean hard water spots off of glass and works great on over spray. Of course don't use it in the inside of your Windows if they are rented.
  8. Feb 6, 2012 at 8:48 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I agree with the rest of the glass, I would just not trust it on the windshield. I figure if I scratched it as easily as I did, then I would be hesitant. But by all means, use it on your windshield.
  9. Feb 6, 2012 at 8:49 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    The film (pvb) is between the two layers of glass not outside.
  10. Feb 6, 2012 at 8:50 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    You will be fine, its tempered and laminated and damn hard to shatter.
  11. Feb 6, 2012 at 8:50 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    lol thats the other reason you will be fine :p
  12. Feb 6, 2012 at 8:53 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I'm no glass genius, but it scratched pretty easy. And my bad, always thought film was on the outside of the glass. Figured thats why it scratched so easily.
  13. Feb 6, 2012 at 8:55 AM
    xJuice
    Josh
    North DFW
    07 DCSB Sport 2wd
    Tempered is only on the sides and back of your car. Tempered isn't generally used in laminated applications.
  14. Feb 6, 2012 at 9:08 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Thats what I meant :spy:
  15. Feb 6, 2012 at 10:32 AM
    Juggernaut
    Sacramento
    I'll try some fine steel wool today, if it doesn't work I'll take it back to the body shop. They did paint my driver doors and bed side, I assumed they would tape up the windows, but maybe not. I really don't want to take it back to this shop again though, im pretty sure they dropped a tool and dented my hood, but that is impossible to prove, and I already had to take it back once so they could reapply a decal.
    Should I apply any type of cleaner or lubricant prior to going at it with the steel wool? It is on the windshield and back windows only.
  16. Feb 6, 2012 at 11:04 AM
    A_Ninja_Racer
    Tampa, FL
    I would spray it with Windex or any other window cleaner. And just keep in mind you don't need to use any elbow grease at all just press hard enough that you can feel the surface of the glass with your fingertips as you slide across the surface once the over spray is gone it should glide smoothly accross the glass.
  17. Feb 6, 2012 at 3:41 PM
    Juggernaut
    Sacramento
    Looks like the steel wool did the trick, I'll double check tonight because it's actually easier to see at night, but I can't find any trace of it! 000 extra fine steel wool was the type I used and it came right up with light to moderate pressure and turned it all into a white powder that I was able to wipe right up. So thank you guys!
    Now I do have some very stubborn water spots on the passenger side windows and door panels from a rogue sprinkler that the steel wool did not work on. Any suggestions for that?
  18. Feb 6, 2012 at 3:43 PM
    06TACOFIREMAN
    06TACOFIREMAN BaNgArAnG
    Caleb
    Alabama
    2002 Tacoma TRD offroad
    toytec 2in lift, 2nd gen trd offroad wheels, yakima roof rack, tool box, magnaflow muffler in the mail
    lacquer thinner!!!!!! except not really. use an adhesive remover and a razor blade
  19. Feb 6, 2012 at 3:46 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    my windshield got scratched from the brillo pad side on a sponge... so yea i for one wont be using anything like that anymore. but hey to each their own. ive used a straight razor with good results before. just my .02
  20. Feb 6, 2012 at 3:52 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    If you bought it used the previous owner may have done like me and put a layer of that ceramic insulator stuff on it and scratched that, but the previous posters are correct the film is in between the glass. I have a scratch on my back window that was there when I bought the truck though so I kind of know what you're talking about.
