something popped and now its leaking oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TacoWJB, Feb 18, 2012.
  1. Feb 18, 2012 at 4:31 PM
    03TacoWJB
    03TacoWJB [OP] Well-Known Member
    03 Access Cab SR5
    i have a 2003 v6 4x4 i put it in park after driving it 1/4 a mile and something just popped and now its leaking a brownish oil at the very bottom of the engine any ideas to what it could be?
  2. Feb 18, 2012 at 4:37 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    You need to drop the skid plates, raise the hood and see where the oil is coming from. Is it motor oil?, power steering oil?, air compressor oil, Brake fluid? Brownish oil tells me it's probably motor oil. Maybe from the oil filter. I have no ideal why there was a pop unless the filter fell off and bounced around.
  3. Feb 18, 2012 at 4:43 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    it might just be motor oil that has collected on the skid plate. happened to me a couple times.
  4. Feb 18, 2012 at 4:53 PM
    03TacoWJB
    03 Access Cab SR5
    see but when i turn it on it vibrates bad the ill put it in gear and the vibration goes down some but if i push on the gas it picks up again and it is motor oil because the dip stick doesn't have oil on it
  5. Feb 18, 2012 at 5:01 PM
    03TacoWJB
    03 Access Cab SR5
    also it doesnt have any signal lights on the dash for it
  6. Feb 18, 2012 at 5:19 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If there is no oil on your dipstick DONT RUN THE MOTOR!
    Find out where the oil is leaking from.
    Maybe you blew a rear main seal?? :notsure:
  7. Feb 18, 2012 at 5:24 PM
    03TacoWJB
    03 Access Cab SR5
    okay yea it is the very bottom back so it might be that ill try to take off the skid and look tomorrow
  8. Feb 18, 2012 at 6:15 PM
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    OMFG, this guy....has no luck, and is driving his truck with no oil. :eek:
  9. Feb 18, 2012 at 8:19 PM
    03TacoWJB
    03 Access Cab SR5
    it still had some oil when i drove it 1/4 a mile without pushing on the gas
  10. Feb 20, 2012 at 5:17 PM
    rngrchad
    08 Rugged Trail TRD
    It's ok to run it without oil for a few days. Just don't go a few weeks. Toyota's are one of the few vehicles that oil is actually an option.
  11. Feb 20, 2012 at 5:19 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    interesting
  12. Feb 20, 2012 at 5:28 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    What are you talking about? :der:
  13. Feb 20, 2012 at 9:47 PM
    TacoMX
    Jonathan
    Deltona, Florida
