Something started rattling under the hood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Dec 25, 2021.
  1. Dec 25, 2021 at 10:47 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    It never ends. Apparently, at 13 years, shit starts to fall apart.
    Anyway, something started rattling under the hood under hard (but not reckless) acceleration. It *sounds* like it’s coming from the middle left area of the engine bay.
    I did a basic visual inspection and didn’t find anything.
    What’s the line-up of usual suspects?
    Thanks.
  2. Dec 25, 2021 at 12:32 PM
    Waasheem
    Waasheem
    2007 xrunner
    Are you running regular fuel, as in low octane? If yes, something you could try is treating her to a tank of premium and a can of good quality in tank cleaner, I like Jectron.
    I only use premium because I don’t like hearing rattling under acceleration. Everyone, or most would say I like to waste money, which is fine with me, mine to waste.
  3. Dec 25, 2021 at 12:46 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Get a good grip on things and start shaking them. You'll find it. Maybe the battery tie-down is loose/broken?
  4. Dec 25, 2021 at 12:55 PM
    Plasmech
    Thanks for the reply. I run Costco 93.
  5. Dec 25, 2021 at 12:56 PM
    Plasmech
    Good thought, I’ll check it out.
  6. Dec 25, 2021 at 1:08 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    How many miles do you have on your truck?
  7. Dec 25, 2021 at 1:27 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Cat cover
    TomTwo likes this.
  8. Dec 25, 2021 at 1:38 PM
    Plasmech
    115k
  9. Dec 25, 2021 at 1:39 PM
    Plasmech
    How do I check it? Hard to replace? Thanks.
  10. Dec 25, 2021 at 1:43 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    I thought the same. Not really a replacement part. The aluminum “shield “ by the cat, next to the firewall might be loose. It’ll be leaning on the cat if it is. Take the bolt off the bracket under it, put a washer bigger than the hole the bolt left, and tighten. Check the cats under the cab as well, that’s where my rattling was.
  11. Dec 25, 2021 at 4:23 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Air intake where it enters passenger side fender foam insulationwears and then the plastic intake rattles.against fender cutout
    dk_crew likes this.
  12. Dec 25, 2021 at 8:44 PM
    Gtlegacy
    Gtlegacy Active Member
    Have you taken a look at your idlers and tensioner pulley? Saw a neat trick in the past. Take a small plastic cup and cut a hole in the bottom. Feed a loooong extension through the hole. When you push the extension against the pulley bolt at idle the cup will act like a speaker so you hone in on bearing noises. I had a pulley failing and had a rattle only at certain rpm which sounded like a bad engine rattle . Be careful when working around moving accessories.
  13. Dec 25, 2021 at 9:35 PM
    Waasheem
    Waasheem
    2007 xrunner
    I like this idea much better than the wooden dowel. Imagine oops my hand slipped and the wooden dowel hit a moving pulley and drove it 6” into my ear.
  14. Dec 26, 2021 at 8:28 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Well u probably wouldn’t hear the rattling anymore
  15. Dec 26, 2021 at 8:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Jimmyh likes this.
