Something wrong with 4c4 I think??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tpham18nm, Feb 29, 2016.
  1. Feb 29, 2016 at 12:35 AM
    tpham18nm
    tpham18nm [OP] Well-Known Member
    Hello TW,
    I think something is wrong with my 4x4 system. Long story short, so I thought I turned on the AC, but instead I switched it to 4h in a parking lot. Pulled the truck out and noticed that the steering was really difficult to turn. Switched it back to 2wd. Maybe this is relevant?
    Anyways, normally while switching to 4Lo both my Auto LSD and traction light is on. Now while switching to 4Lo only my Traction light is on. Spent about an hour trying to get the Auto LSD light back on (like how it normally is). Any tips on how to get the system turned on? I'm afraid something went wrong.
    I took out the battery to reset the computer. Nothing changed...
    I drive a 2010 regular cab Tacoma 4x4. All stock.
  2. Feb 29, 2016 at 1:22 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Have you driven it since this happened? Sounds like your VSC (vehicle stability control) is turned off. You push and hold the button (veh with squiggly traction lines "off") for 3-5 seconds and this turns the VSC off. It will automatically turn back on after 30 mph. Or just push the button again to turn the VSC back on.
    If your VSC system isn't turning back on then you may have a blown fuse. Given your confusion though between the A/C control and the transfer case switch, this may just be a case of operator error. Try pushing the VSC off button.
    Have a good read of this thread if you haven't already.
    https://www.tacomaworld.com/threads...rols-trac-auto-lsd-a-trac-rear-locker.212057/
    Let us know what happens.
  3. Feb 29, 2016 at 1:57 AM
    tpham18nm
    Yes I driven the truck after the incident. I think I just confused the crap out of myself actually.
    I can turn Auto LSD and trac off in 2wd.
    I can turn off trac in 4h by holding down the trac off button (truck with squiggly lines)
    In 4Lo my trac icon is always illuminated. Is the "auto lsd" light suppose to be on in 4lo?? Was it ever on? Or am I getting confused?
  4. Feb 29, 2016 at 2:17 AM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    oh shit - you were talking about 4lo. In 4lo.. TRAC is off. You have no traction control or VSC in 4lo. All open diffs. Not even auto LSD. That's normal.
    If you want auto LSD in 4lo, (which.... why wouldn't you?) do the yellow wire mod. search it. It's easy to do and well described here.
    And if you didn't read that like I sent you, read it. It actually answers your questions. The VSC, TRAC, Auto LSD stuff changes in each mode (2,4hi,4lo) and it's not really common-sense. You need to read it to understand how it works, when it works, and your different options in each mode. You will likely have to read it every once in a while if you want to keep it all clear.
  5. Feb 29, 2016 at 4:28 AM
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    Auto LSD is only an option in 2WD when the case is in 4WD you won't see Auto LSD when you toggle traction/stability. So when you are in 4WD if you don't see the AUTO LSD light that is normal.
  6. Feb 29, 2016 at 12:33 PM
    tpham18nm
    Oh wow. I must have been tripping yesterday. I'm glad everything is okay in my truck. Thanks for the reply
