Something wrong with my 4H?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TenderTacoNipples, Oct 18, 2019.
  1. Oct 18, 2019 at 7:41 AM
    TenderTacoNipples
    TenderTacoNipples [OP] Well-Known Member
    2012 Tacoma DCLB SR5
    So last night it was particularly rainy and stormy and I wanted to try out my 4wd since I just bought this truck a couple weeks ago. I put it into neutral, switched it, and then waited a bit and put it back into drive, just like how my 03 4runner was.
    My truck drove fine straight but once I slowed down and pulled into a parking lot the back wheels started.... lagging? its almost like every time I turned the wheel the back wheels would be dragged? My 4runner never did something like this in 4wd. It freaked me out so I stopped the truck, put it back into neutral, switched it, and then drove forward again, and while the 4Hi sign was blinking "clunk" and then it stopped blinking and left me with massive paranoia that I just destroyed my diff or transfer case.
    I tried to re create it and sure enough it was the same thing. I dont think my P brake was stuck but I have heard of the drum brakes getting frozen up, but then why would it only happen when I'm taking turns? WTF
    Has anyone experienced this before? Do I need to take it in? Am i crazy? Please help Lol
  2. Oct 18, 2019 at 7:43 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
  3. Oct 18, 2019 at 7:44 AM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    Was you on asphalt or dirt?
  4. Oct 18, 2019 at 7:49 AM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Your 4x4 is working fine but you aren't supposed to make sharp turns in 4x4 without being on snow or loose gravel. Someone here can explain better what happens mechanically but it's not good for your differentials
  5. Oct 18, 2019 at 8:03 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    First why are you stopping and shifting into neutral to put the truck in 4WD and take it out of 4WD? No need to do either unless your going into 4L and it doesn’t sound like you are.
    I’m not sure what you mean by the rear wheels dragging. Since it only happens when turning it sounds like the road surface isn’t slippery enough and the front wheels are binding up which is expected. Take it out on some gravel or loose dirt or muddy roads and try it. I think you won’t have a problem.
    RobP62 and TenderTacoNipples[OP] like this.
  6. Oct 18, 2019 at 8:03 AM
    Muddinfun
    Muddinfun Well-Known Member
    The larger the radius(the bigger the circle), the farther the wheels have to go.
    RobP62 likes this.
  7. Oct 18, 2019 at 8:04 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Working fine. No need to switch to neutral.
    TenderTacoNipples[OP] likes this.
  8. Oct 18, 2019 at 8:06 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
  9. Oct 18, 2019 at 8:07 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    your 03 4runner had a center locking diff for an AWD mode.... your part time 4x4 tacoma transfercase does not. As others have said above, only straight line driving on high traction surfaces or on the slippery stuff in 4x4.
  10. Oct 18, 2019 at 8:40 AM
    TenderTacoNipples
    Ok that makes sense, like I said I've only owned this truck a few weeks and still figuring it out, and I can just switch between 2H and 4h while driving? I'm not used to this new shit lol
  11. Oct 18, 2019 at 8:42 AM
    TenderTacoNipples
    Thank you all for the quick responses, i didnt sleep good last night wondering if i just bought a fucked up truck lol, taking her into some mud this weekend :D
    whatstcp and Muddinfun like this.
  12. Oct 18, 2019 at 8:47 AM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    Yea you can switch between 2H and 4H while driving up to like 55mph or something...says in the manual. Best just to put some weight in the bed for driving in light snow and rain on pavement instead of using 4H.
  13. Oct 18, 2019 at 8:51 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Good luck in the mud O.P.
  14. Oct 18, 2019 at 8:53 AM
    Muddinfun
    "Hold my beer and watch this shit" usually turns out to be a bad decision.
  15. Oct 18, 2019 at 5:52 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    On any surface where you get a lot of traction, you'll get some binding in the drive train, in 4wd. All of your wheels are travelling a different distance. It's normal, although not the best for the system, to pop when it disengages. Again, you don't want it to do this, but it does. When I have to shift back to 2wd, if traction is not a little loose, I'll keep the wheel straight and go forward and backward a couple of feet to try and take some of the binding out of the system. Sometimes it works, sometimes it doesn't.
    Just try to avoid using 4wd where traction is good.
