Something wrong with sub
Discussion in 'Audio & Video' started by Jaybo, Jun 2, 2009.
  1. Jun 2, 2009 at 6:57 PM
    Jaybo
    Jaybo [OP] Well-Known Member
    Jaybo Talbo
    SC
    07 PreRunner
    Well, the story is... My 760 watt amp and two 10"s were professionally installed and never had any trouble with them. 2 months later I replaced the two 10"s with a 15" sub. The 15" worked well for a couple weeks...
    Then it quit working all together. I have checked all the wires (including inside the actual box), fuses, and the amp light turns on. And everything looks alright.
    So I have no idea what else to check. Is there anything else I am missing to check? Or anything I need to do to get it working again?
  2. Jun 2, 2009 at 6:58 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    Is the amp working fine? One day my sub stopped working all of a sudden. It ended up being that the power cable came loose (where it connects the the amp)
  3. Jun 2, 2009 at 7:01 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    also check the amps fuses if it has them if done professionaly you might want to check the fuse they should have put in by the trucks battery but if the lights turn on for the amp then check all connections to speakers inside the box they might have cam off
  4. Jun 2, 2009 at 7:03 PM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    I hear ya, but yeah I have checked all of the wires connecting to the amp, the stuff connected to the battery, and the wire that is connected to the fuse box.
  5. Jun 2, 2009 at 7:04 PM
    Mac2118
    Mac2118 Well-Known Member
    Pennsylvania
    01 Tacoma SR5
    if you push down *gently* on the cone of the sub, do you feel any resistance? sometimes if it feels scratchy you have a blown sub and would want to check it with a multimeter
  6. Jun 2, 2009 at 7:06 PM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    The fuses in the amp look good, and I will check the wires inside the box again and check everything else again tomorrow too. Just to make sure, but I have done all this stuff several times in the last couple of weeks and nothing looks out of place or bad.
  7. Jun 2, 2009 at 7:06 PM
    johnw
    john
    orlando florida
    so everything is connected?
  8. Jun 2, 2009 at 7:08 PM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    Excuse my ignorance, but what is the cone of the sub? And I thought the way you know it is blown is if it has a distinct smell
  9. Jun 2, 2009 at 7:09 PM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    Yup, right now I am 100% sure. But I can definitely check again in the morning
  10. Jun 2, 2009 at 7:24 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    the CONE is the part of the sub that moves when it's playing.
    Not so sure about the smell technique of how to tell a sub is bad though...
    When you move the cone, it may or may not try to play. If it's not smooth in movement, it might be a bad sub.
    Grab any speaker and hook it up to the amp...you don't need to turn it up, just checking to see if it's sending signal to the speaker. You are just trying to eliminate the amp.
  11. Jun 2, 2009 at 7:35 PM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    True true, I will have to try hooking up a different speaker to the amp then cause that's a good idea
  12. Jun 2, 2009 at 7:42 PM
    Mac2118
    Pennsylvania
    01 Tacoma SR5
    smelling a speaker with the burning smell doesn't necessarily mean that its blown. sometimes after getting a new speaker or getting one reconed you will smell the excess glue. yeah, there is quite a distinct smell, but better safe than sorry.
    if it makes you feel any better, the rca outputs on my head unit are bad and my speakers pop because of the signal interrupts
  13. Jun 4, 2009 at 12:35 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    You can also use a AA or 9v battery. Hook it up to the speaker wire leads going into the speaker and see if the cone moves that way. Also a great way to check to make sure the polarity of the speakers are correct (sometimes the factory has them backwards).
  14. Jul 2, 2009 at 7:03 AM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    well sorry i never got back to this thread i made, but i just gave up on it and im just gunna sell locally as is. but thanks y'all
  15. Jul 2, 2009 at 10:03 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Woah woah woah....let's not get hasty
    Did you test the sub with a 9V battery to see if it made any audible sound?
    Also, each of the terminals that you connect the speaker wires to have what is called a "tinsel lead" that runs from the terminal to the center of the sub. Are the tinsel leads still connected to the terminals? Sometimes these can break off or disconnect.
  16. Jul 2, 2009 at 10:24 AM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    wow. didnt figure you would give up and quit just cause it aint werkin right!!!!!! troubleshoot it some and figure it out!
