something's up w/ my suspension...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaxPower, Jan 1, 2011.
  1. Jan 1, 2011 at 3:36 PM
    MaxPower
    MaxPower [OP] Truck Noob
    Cezar
    Connecticut
    09 DCLB Taco TRD Sport
    as stated, i fear something has happened to it. the rear driver's side seems like it's sitting 2" lower than the rear passenger side. it's all OEM suspension/leafs as i have not yet tinkered with it, nor have i taken the tires off ever, (only have had it for 8000 or so miles, though it is at 25555), or had any TSB's done on it.
    however, i did put in the bed, behind the axle, two tuffboxes with 3 bags of tubesand each, (totaling 360 lbs of weight), to weigh the rear end down for the winter. it's centered pretty evenly between the bed walls and against the tailgate and strapped down securely as well.
    there's no way that could cause the suspension to sag like that, would it? i've never taken it off-road, nor driven it like an asshole (yet) and up and over things.
    def still a warranty on it, so the dealer should def help me out, right, or will they say something about the weight in the rear, even though they are rated for like 1200 lbs payloads...?
    i'll try to post pic later. thanks for any help in advance.
  2. Jan 1, 2011 at 3:39 PM
    MaxPower
    Cezar
    Connecticut
    also worth noting that it doesn't seem to pull in one direction or another while driving, which i found a bit odd.
  3. Jan 1, 2011 at 3:41 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    sounds like the gas tank is full. that will cause it to lean.
  4. Jan 1, 2011 at 3:43 PM
    MaxPower
    Cezar
    Connecticut
    seriously? and i am at 3/4 full. i never noticed it before.
  5. Jan 1, 2011 at 3:49 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    taco lean still shouldnt be a whole 2" though....
  6. Jan 1, 2011 at 3:53 PM
    907taco
    Bobby
    Alaska
    start over and see what is happening, take everything out of the truck and see how it sits, if that doesn't work, take a look at your suspension, stand on your bumper and jump up and down. Not sure if that will solve your problem, but its a start
  7. Jan 1, 2011 at 3:55 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    maybe hes got a bad shock?
  8. Jan 1, 2011 at 3:57 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    x2 sounds like a shock is stuck or bent
  9. Jan 1, 2011 at 3:58 PM
    907taco
    Bobby
    Alaska
    also take a look at all your suspension, like above post. could be that also
  10. Jan 1, 2011 at 10:05 PM
    MaxPower
    Cezar
    Connecticut
    if this is the case, am i covered by the warranty/dealer?
  11. Jan 2, 2011 at 12:06 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    it should be, unless the dealership finds a way to say that the blown shock was your fault
  12. Jan 2, 2011 at 12:11 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    which they'll do...f it...I smell Bilstein 5100s in your future :D
    Good luck bud
  13. Jan 2, 2011 at 2:47 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    is it just me or arent shocks just supposed to dampen the suspension, not any actual weight support? take it to the dealer and have it handled, that is what the warranty is for.
  14. Jan 2, 2011 at 3:11 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    ^x2 I say let the dealer look at it.
  15. Jan 2, 2011 at 10:37 AM
    My6AteUr8
    My6AteUr8 Member
    Joel
    VA
    01 TRD
    3" suspension lift, open air intake, TRD supercharger, 33x12.50 DC Crusher Tires on DC rims
    I've had 2 different Tacoma's in the last 8 years. Both of my trucks did this same thing. I've seen posts about it in another Taco forum that I'm a member in and this seems to be a common thing with Taco's. Note the consistent weight on the driver side (driver and gas tank) versus the lack there of on the passenger side. It's not a big deal and most people don't even notice it. If you're looking to correct it, I would suggest upgrading your leaf packs.
  16. Jan 2, 2011 at 2:15 PM
    MaxPower
    Cezar
    Connecticut
    if this is normal, i find it hard that it would be 2", and that i never noticed it before. also, why the hell would this be normal...why couldn't Toyota even it out...?
  17. Jan 3, 2011 at 12:19 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    taco lean is normal 2 inches is not, if you went over a bump and one shock got bent or stuck while compressed it can cause your lean
  18. Jan 3, 2011 at 12:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    ^this^ The only thing that might be broke that would cause this is the spring perch or where the mount is welded to the shock bottom.
    :wave:
  19. Jan 3, 2011 at 5:24 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    YES! When I replaced my rear shocks, I unbolted them and removed them by hand w/o jacking up the truck. The rear leafs take all of the load, the shocks take the brunt of the high frequency loads and help absorb the impact.
    One thing could be that the previous owner overloaded the bed once before and damaged one of the leaf packs. It could be the added weight (sand bags) are causing the 2" and your truck can't handle the added weight now. Just a thought.
  20. Jan 3, 2011 at 6:53 PM
    907taco
    Bobby
    Alaska
    op, did you figure this out yet?
