Sometimes get no response when turning key to START
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Nov 21, 2017.
  1. Nov 28, 2017 at 8:18 AM
    #41
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Nope, just this. I will try doing it with clutch start cancel a few times just to see if I can recreate the problem.
    Here’s a neat video I found.. he says if you hold the key to START for a while and finally the starter kicks in, it could be a bad starter. I unfortunately didn’t have an OEM starter, I have an OEM alternator... so I’ll have to get a new one.
    https://youtu.be/DpkDW2zUCms
    wolfpackbd22[QUOTED] likes this.
  2. Nov 28, 2017 at 8:21 AM
    #42
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I believ the electrical part of the ign switch is just held in with 2 screws. Just drop the lower column cover and knee bolster.
  3. Nov 28, 2017 at 8:22 AM
    #43
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So I’m guessing it’s almost the same as the first video I linked on the previous page? The one of 2003 4Runner.
    Gonnna try the “hold the key in start position” trick and go from there. If the starter finally does something after a few seconds then I’ll replace it.
  4. Nov 28, 2017 at 8:28 AM
    #44
    mechanicjon
    Jon
    Scottsdale Arizona
    Yes very similiar
    ThunderOne[OP] likes this.
  5. Nov 28, 2017 at 8:47 AM
    #45
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Dollars to doughnuts it's the ignition switch...
  6. Nov 28, 2017 at 2:50 PM
    #46
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    yes that is the part. some call them cylinder and others call them switch. nothing to do with the actuall key - it is the electrical connection the key makes when it makes contact after turning. next time it dies on you look closely at the position of the key. if it is the switch/cylinder the key will have returned to the off or acc position. it is the electrical connection created between the key and switch which keeps the key in the one position. if the switch is bad the connection fails and the key returns to a non-run, no electrical contact, position. the key should stay in the on position each time it is turned to run. hard to get into - like standing on your head and working. A pain the the ass but not complicated. just take your time and be sure you have all the plastic shields out of your way and a good light source to see what you are working on.
  7. Nov 28, 2017 at 3:21 PM
    #47
    cliffyk
    Cliff
    Saint Augustine, FL
    The cylinder is the cylindrical rotating component that accepts the key, it us carried by the cylinder housing (body). When turned it unlocks the steering wheel and rotates the switch armature to power up the car and start the engine. The switch mounts typically at the rear of the body:
  8. Nov 29, 2017 at 9:32 AM
    #48
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    considering a new OEM ignition switch is going to be $88, I'm going to remove the starter and get it replaced since it's a lifetime :rolleyes: unit. Then if that doesn't fix it, I'll go ahead and bite the bullet on a new ignition switch.
  9. Nov 29, 2017 at 9:44 AM
    #49
    cliffyk
    Cliff
    Saint Augustine, FL
    On a 1st gen I'm sure it will come apart allowing the contacts to be cleaned/reshaped/lubricated...
  10. Nov 29, 2017 at 9:53 AM
    #50
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That’s true, though I tend to break small electrical things encased in plastic more than I care to admit :oops:
    mechanicjon likes this.
  11. Dec 1, 2017 at 8:42 PM
    #51
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    https://youtu.be/QmsO0X9joJw
    This time I held the key on START and eventually the starter kicked in. So per the video at the top of this page, I’m guessing the starter is to blame at this point.
  12. Dec 1, 2017 at 8:47 PM
    #52
    mechanicjon
    Jon
    Scottsdale Arizona
    Any way possible you can hold a test light on the solenoid wire at the starter? Then have someone turn the key. See if the solenoid is getting power when it's not starting.
  13. Dec 1, 2017 at 8:53 PM
    #53
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I bet I could. Problem is, since this happens randomly, I would have to find a way to do it by myself. I’m gonna see if I can get a new starter tomorrow (should be $0 anyways) and report back in a week or so. If I can’t recreate the problem then I should be good to go.
  14. Dec 11, 2017 at 2:00 PM
    #54
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Swapped the starter, so far so good after about 20 or so starts since install. I think it was bad contacts on the starter. Just FYI, these "lifetime" units only apply to the first unit. Once you swap it out once, you have 90 days from the point you receive the second one for a warranty. Which means when this happens again, I'll need to get a contact kit.
    FWIW the carquest reman starter from Advance is super quiet. I like it.
    ghs57 and cruiserguy like this.
  15. Dec 12, 2017 at 2:19 AM
    #55
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    Awesome. Hopefully that is it.
    FYI, don't know if I posted it or not, but my 2000 has original starter and new contacts around 291k are all that's been done.
    ThunderOne[OP] and cruiserguy like this.
  16. Dec 12, 2017 at 7:05 AM
    #56
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not bad. I've about to roll over 180k. I killed my first starter in high school when I thought "mudding" was cool :bananadead:
    This time I'm pretty sure my leaky valve cover gaskets were a contributing factor..
  17. Dec 12, 2017 at 7:15 AM
    #57
    rybern
    N Alabama
    I remember those days. First time I went mudding was in my 79 Buick Regal..... seriously. I've been avoiding mud for the past 25 years.... for the most part anyway.
  18. Dec 17, 2017 at 12:05 PM
    #58
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Bump. I'm having a similar problem.
    @ThunderOne When your truck wouldn't turn over with the key in the ignition, did you have power to all of your accessories or not? Obviously nothing would turn on as there was no response when turning the key, but did your power door locks still work, for example? I'm having a very similar problem, except that when the truck won't turn over, I also lose all power to any accessories... suggesting a dead battery (or something un-related to the starter). Then after a few tries, it'll start up like normal and I'll regain all power functions.
    I got my battery load tested today at 530-something CCA's. It's an Optima Red-top, bought back in 2010 by the previous owner. I'm just trying to figure out if it's starter-related or battery-related... my thought would be battery-related, because if it was a problem within the starter, I'd still have power to the door locks, headlights, etc.
    The problem is, it always starts up fine after a few tries... which doesn't sound battery-related to me, right?
    Am I correct in my thinking?
  19. Dec 17, 2017 at 12:28 PM
    #59
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    With the key in the ignition and turned to the 'ON' position (after trying to start the key moves to 'ON' automatically) you don't have power to accessories or windows, etc? I'm just making sure I understand correctly.
  20. Dec 17, 2017 at 12:44 PM
    #60
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Correct. No power when the key is in the ON position.
