Sometimes Truck Starts - Sometimes it Doesn't
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Larry, Jun 16, 2016.
  1. Jun 25, 2021 at 1:28 PM
    Tacotint310
    Tacotint310 Member
    Hello TRD Larry
    Long shot but did you end of finding the issue with this 2009 not starting ?
    I’m having the exact problem with my 2008
    Tia
  2. Jun 25, 2021 at 3:32 PM
    TRD Larry
    TRD Larry [OP] trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Yes. It was the transponder amplifier that is located behind the gauge cluster. The part was $450 from the dealer.
  3. Jun 27, 2021 at 10:37 PM
    Tacotint310
    Tacotint310 Member
    Thank you Larry
    I hope this solves my issue
  4. Jan 16, 2023 at 12:13 PM
    jiggee11
    jiggee11 Active Member
    nj
    06 basic 4x4
    Hi, yours was cranking but not starting correct?
    Because my 2006 Tacoma, sometimes cranks and starts and sometimes it doesn’t crank at all. I can sit the for a while turning the key and nothing and then I can come out and it starts right up. Not sure what it is. I did change the PN switch on it and the gears are now marking the correct response on the dash. But I get the no crank at all symptoms.
  5. Jan 16, 2023 at 2:44 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the battery connections
    BassAckwards likes this.
  6. Jan 16, 2023 at 3:06 PM
    jiggee11
    nj
    06 basic 4x4
    Yes I cleaned the terminals checked the fuse and relay for the starter, they are good, I think maybe could be the starter but not sure. It started happening after I changed the prndl switch on the side of transmission.
  7. Jan 16, 2023 at 3:09 PM
    jiggee11
    nj
    06 basic 4x4
    I also cleaned the connections at the starter.
  8. Jan 16, 2023 at 3:11 PM
    jiggee11
    nj
    06 basic 4x4
    I tried moving the parking neutral switch back-and-forth as my wife was turning the key to see if that does it but it still did not crank at all sometimes you turn the key and it cranks but most of the time you turn the key and nothing happens no crank no nothing
  9. Jan 16, 2023 at 3:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check for a signal coming out of the ignition switch in the crank position
    TwistedOmYoga likes this.
