Sony head unit is unresponsive
Discussion in 'Audio & Video' started by samgnight, Apr 6, 2011.
  1. Apr 6, 2011 at 6:51 PM
    samgnight
    samgnight [OP] Member
    Sam
    I have a Sony CDX-GT630UI head unit. I moved it from an '09 Camry (working perfectly) to an '11 Tacoma. I used the same connections as I did in the Camry. Sometimes the head unit comes on randomly, but it usually never comes on. When it does come on, none of the buttons are responsive. NONE. Any help would be greatly appreciated.
  2. Apr 6, 2011 at 6:57 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    1st thing I would check are the quality of the power and ground connections. A poor ground could produce this sort of issue.
  3. Apr 7, 2011 at 6:54 AM
    samgnight
    Sam
    Everything looked fine, but I went ahead and pulled apart the wire harness and taped everything back together again. No luck. I'm not sure how I figured this out, luck I guess, but it has to do with the radio connection (looks similar to the end of headphones). When it is plugged in, the head unit doesn't respond to any button presses. When it is disconnected, everything works fine, except the radio, of course. This isn't a problem for me though as I only listen to my iPod. I do find it quite odd that the radio connection would be the source of the problem though.
