sooo dilemma...
Discussion in 'Suspension' started by snowgod06, Feb 15, 2011.
  1. Feb 15, 2011 at 8:58 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    So i have a spacer lift and now im wanting to upgrade to something that doesnt suck. When me Tax return gets here ill have about 500 to spend.
    Question is for 500 could i get a lift that is the same height if not more then my spacer lift?
    this is one kit im looking at but would take ANY options. http://www.skyjacker.com/product.php?ProdID=8519 I've looked at OME and toytec and just not sure.
    And please dont bash me, ive been looking over threads all day. And cant figure out what lift would be better then my spacer for around 500.
  2. Feb 15, 2011 at 9:00 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Bilstein 5100 with eibach springs is pretty standard. And it would help on the height thing is you said how much lift the spacer gave you.
  3. Feb 15, 2011 at 9:00 PM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    billiy 5100's?
  4. Feb 15, 2011 at 9:01 PM
    snowgod06
    Rob
    06 Access Cab
    yea i was thinking that to. my spacer is only like 1.5-2in tall with a block in the rear.
  5. Feb 15, 2011 at 9:02 PM
    S.B.
    Sean
    Then that setup would be for you. I'm guessing that you don't go to the desert and romp it, correct?
  6. Feb 15, 2011 at 9:04 PM
    snowgod06
    Rob
    06 Access Cab
    well not romp it, but my truck does get worked on pretty hard on the dunes and in the mtns here in oregon. Mostly 5mph or less wheeling speeds on trails tho lol
  7. Feb 15, 2011 at 9:05 PM
    S.B.
    Sean
    If you haven't killed your current setup and don't plan on beating the truck much harder then you should be fine.
  8. Feb 15, 2011 at 9:08 PM
    snowgod06
    Rob
    06 Access Cab
    i mean, would 886's up front with billies at 2.5, with a AAL and billie in rear be about right?
  9. Feb 15, 2011 at 9:11 PM
    S.B.
    Sean
    NO. with no-stock springs and billies DO NOT add preload to the springs. Leave the bilies at 0, but with the eibach springs and bilies you can set them up to the .85" setting with weight up front (i.e. after market bumper). Get rid of the block and replace with AAL.
  10. Feb 15, 2011 at 9:13 PM
    snowgod06
    Rob
    06 Access Cab
    so... coils and billies up front sent at .85, AAL in rear with billies. i think thats what i got out of your post lol
  11. Feb 15, 2011 at 9:15 PM
    S.B.
    Sean
    If I were you, I would get bilies and set them at 0" with the eibach springs that you can get from Toytec for the front.
  12. Feb 15, 2011 at 9:21 PM
    Surfinpig
    Surfinpig Well-Known Member
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    Avid Offroad light bar, trd skid plate, are cap, billy 5100's
    I ordered my lift the other day. Bilstein 5100’s front and rear from Down South Motor Sports, $283.00 shipped. Tuff Country 2” add a leaf from Suspension connection $66.53 shipped. Call Down South and tell them your from TW for that price. My Taco is a 2010 access cab 4x4 SR5 2.7L
    I've been looking and searching for a while this is the best price I could find. From the sound good thing I didn't do a spacer.
  13. Feb 15, 2011 at 9:23 PM
    snowgod06
    Rob
    06 Access Cab
    how much lift up front are you expecting? I'm just unsure about cranking the billies up on stock coils to get me at the same height as my spacer lift i have now.
  14. Feb 15, 2011 at 9:25 PM
    S.B.
    Sean
    You can crank up the bilies on stock coils. To have the same amount of lift you have now (about 2", right?) put the bilies at the 1.75 mark.
  15. Feb 15, 2011 at 9:27 PM
    snowgod06
    Rob
    06 Access Cab
    hmm.. Gah..choices. Well thanks S.B. for the info. Time to do more thinking..
  16. Feb 15, 2011 at 9:34 PM
    S.B.
    Sean
    No problem.
