Soot on rear, above exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cstephan, Aug 15, 2012.
  1. Aug 15, 2012 at 5:28 AM
    cstephan
    cstephan [OP] Jack Of All - Master at none
    Hendersonville, Nc
    17 Taco TRDOR -DCSB- Gov. Controled Special
    Hold my BEER and WATCH THIS
    Tw,
    I have a white tacoma with the V6, 6spd manual. It is a 2011 with ~25,000 miles. I run moble 1 syn and change it every 3,500-4,000. i have changed the air filter at 10,000 and 20,000. does any one else have soot above the exhaust? i also live at 2,800 FT elv. and run 87 with the 10% ethonal. What do you guys think? i am blown away. do thease truck just run rich?
  2. Aug 15, 2012 at 5:30 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Yes, they run rich from the factory, particularly under open loop acceleration.
    I personally shy away from ethanol, actually I've always run ethanol free premium fuel, and I have plenty of soot. Nature of the beast with these trucks.
  3. Aug 15, 2012 at 5:49 AM
    cstephan
    Hendersonville, Nc
    well, looks like intake, and exhaust are coming soon, and the plug in device that plugs into the MAF from URD
  4. Aug 15, 2012 at 6:00 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    :D Bust out the credit card! Lucky you!
    I don't run a MAF calibrator myself, but you've done your research: that's about the only way to address the issue under hard acceleration. Just be sure to purchase your upgrades first, and get them to tune the calibrator to your individual setup/upgrades.
  5. Aug 15, 2012 at 6:43 AM
    cstephan
    Hendersonville, Nc
    yup, I have enough points to get it all for FREE on my 2 credit cards! been saving for 6 years!
  6. Aug 15, 2012 at 6:47 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Just lop it off and dump it right over the axle. Problem solved! :D
  7. Aug 15, 2012 at 7:04 AM
    cstephan
    Hendersonville, Nc
    I would, but i also want to solve the issue of unburned fuel. could cause O2 sensors to faul up quicker and suck, carbon build up on valves.. i could go on.
  8. Aug 15, 2012 at 7:44 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Before anything I'd get a Scangauge or Ultragauge so you can monitor your lambda values and timing. It could be a matter of sucky fuel (i.e. severely pulled timing could cause unburned fuel too). Have you tried higher octane, maybe 89 or 91?
    If you were running rich the lambda values would be consistently less than 1. As far as timing, my 2.7L (2TR) cruises at ~25-30° BTDC, with dips into the teens on acceleration.
  9. Aug 15, 2012 at 8:01 AM
    BamaToy1997
    Bill
    Navarre, FL
    You cannot avoid a small amount of soot coming from the exhaust. If it is excessive enough to cause black smoke, THEN you may have an issue, but you can look at EVERY car and truck and if you run your finger across the inside edges of the exhaust pipe, you will find soot. Can't do anything about it. Soot is not unburned fuel. Soot is a RESULT of burned fuel when you are looking at exhaust output.
  10. Aug 15, 2012 at 10:41 AM
    cstephan
    Hendersonville, Nc
    mine is visable on the rear panel, right behind the tire.
  11. Aug 15, 2012 at 1:33 PM
    BamaToy1997
    Bill
    Navarre, FL
    Not a matter of safe side or not safe side. federal law mandates that they run it as close to 14.7:1, so you cant play with it. Soot is going to happen on EVERY CAR on the road. The soot showing up on your fender has to do with several factors from where the pipe actually exits the vehicle to how fast you are driving. How about some pics? I would suggest maybe a small pipe end like a custom extension that adds 3 or 4 inches to the pipe length.
