Sorry, but Another Tire Size Question
Discussion in 'Wheels & Tires' started by saf023, Oct 22, 2009.
  1. Oct 22, 2009 at 4:51 PM
    saf023
    saf023 [OP] Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I understand that the OEM 265/65-17 size is the largest tire you can fit without a lift kit. What’s not clear is whether the rubbing is caused by the larger diameter or a wider tire or both. Is rubbing on the front a lock-to-lock front issue only. Can you go any wider on the back without rubbing?.
    275/60-17s, for example, are a half of an inch smaller in diameter but are a half of an inch wider. Will they fit on the front? Will they fit on the back?
  2. Oct 22, 2009 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can fit a 265/70/17 with no rubbing. Rubbing is a combination of too wide, and too tall.
  3. Oct 22, 2009 at 4:56 PM
    saf023
    East Coast
    So you are saying 275/60-17s won't fit on the BACK ONLY without rubbing?
  4. Oct 22, 2009 at 4:57 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Yes, but I am not sure about the 275's you asked about.
  5. Oct 22, 2009 at 5:11 PM
    saf023
    East Coast
    Thanks for the response.
    The closest thing on the back seems to be the brake lines and they are well farther than 1/2 inch. I understand the front can be more difficult to judge but I don't see a 1/2 inch smaller diameter tire rubbing even if it is 1/2 inch wider.
    Does anyone know for sure?
  6. Oct 22, 2009 at 5:16 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I've test drove one with 275/70/16 with no rubbing.
  7. Oct 22, 2009 at 5:18 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    You keep talking about front versus back. I am pretty sure that, because you have a 4x4, you have to run the same size on the front and the back.
  8. Oct 22, 2009 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct.
  9. Oct 22, 2009 at 5:32 PM
    saf023
    East Coast
    Good point. I understand the ABS brakes can sometimes be affected if front and rear tires are not the same but is this also the case with a 4X4?
    I understand you guys are trying to help but keep in mind I'm also asking if anyone has tried a tire that is 1/2 inch smaller in diameter and 1/2 inch wider on both the front and back.
