Sort of a groaning, vibratey noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikaymusic, Apr 10, 2017.
  1. Apr 10, 2017 at 8:49 AM
    mikaymusic
    mikaymusic [OP] Well-Known Member
    07 Tacoma 4x4 SR5 TRD
    07 Tacoma, 168K miles, stock suspension. At low speed, and then again around 35-40 mph is an intermittent sort of throaty vibration noise. Definitely not linear to vehicle speed, definitely not related to engine rpm. Almost more like something is vibrating at a certain frequency. Sounds like it's under the front somewhere, under the cab even. It doesn't always do this. Seems to do it much more often when my wife is in the car with me (so she can complain about it, I guess).
  2. Apr 10, 2017 at 8:54 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    possibly wheel bearing(s) in turns does the sound go away more?
  3. Apr 10, 2017 at 8:59 AM
    mikaymusic
    No, not the wheel bearings...I'm familiar with that noise, and it's not rotational or related to the turning of the wheel. I would guess if there were some sort of guard or something that might be loose and rattles at a certain frequency, something like that.
    It's always the same sound, whether I'm going slow or faster.
  4. Apr 10, 2017 at 9:05 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    U-Joints maybe?
  5. Apr 10, 2017 at 9:08 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Sometimes a broken or dislodged exhaust hanger will act like that. It will only groan when the exhaust is touching a crossmember or something...
    mikaymusic[OP] likes this.
  6. Apr 10, 2017 at 9:42 AM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    I know you said it's not linear to speed, but I would pull your serpentine belt and check every pulley(alternator, power steering, fan, 3 idler pulleys and tensioner pulley) I had a similar noise recently that turned out to be an idler pulley bearing going bad. Worth a shot.
  7. Apr 10, 2017 at 10:00 AM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Does it make the same noise in 4WD?
    outlawtacoma and mikaymusic[OP] like this.
  8. Apr 10, 2017 at 10:21 AM
    mikaymusic
    Haven't tried that. It doesn't always make the noise. It sometimes makes the noise. I'll check to see if it will do it in 4wd.
  9. Apr 10, 2017 at 10:23 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    If the noise goes away in 4WD then it more than likely the front diff needle bearing bad.. A lot of 4WD 2nd gen's have this problem.. ECGS has a bushing replacement instead of the OEM needle bearing
  10. Apr 10, 2017 at 10:30 AM
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    You couldn't hear a dump truck driving through a nitroglycerin plant.
  11. Apr 10, 2017 at 10:38 AM
    mikaymusic
    That may be. Too many years standing in front of guitar amps will do that.
  12. Apr 10, 2017 at 10:39 AM
    Tacoturtle
    Trey
    Athens, Ga
    2015 red dcsb sport
    The thread title sounded like a line from Christmas Vacation. And my mind thinks mostly in random quotes.
  13. Apr 10, 2017 at 10:40 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    That was a great movie
    1G3_Tommy likes this.
  14. Apr 11, 2017 at 3:52 AM
    Blockhead
    Pittsburgh, Pa.
    Is that you uncle Louis?
    Tacoturtle[QUOTED] likes this.
  15. Apr 11, 2017 at 3:58 AM
    Tacoturtle
    Trey
    Athens, Ga
    2015 red dcsb sport
    Damn it, Bethany, he guessed it.
    outlawtacoma likes this.
  16. Apr 21, 2017 at 7:18 AM
    dwc2170
    dwc2170 Member
    Dave
    New Jersey
    2012 Tacoma Double Cab
    Alpine KTP-445U Power Pack
    My 2012 TRD Sport is currently at the dealer for the same thing. All senior technicians cannot definitively identify the problem. I approved the test using sound/vibration to isolate the problem. Did you get yours resolved?
  17. Apr 21, 2017 at 7:47 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    If joints are tight and carrier bearing is ok
    when it makes the noise, put it in 4th and see if it stops. if it stops then your tranny is low on fluid
    also could be MAF sensor needs cleaning
  18. Apr 24, 2017 at 2:52 PM
    dragonle87
    dragonle87 Well-Known Member
    Atlanta, GA
    '13 DCLB TRD Sport
    I'm also experiencing this noise. Thought fender wheel access cover was loose or flapping. Don't see anything hanging or loose.
    Mine tends to be when I put in Reverse on a small incline & throaty or groan noise will occur. Doesn't happen all the time.
    Suggestions?
  19. Apr 24, 2017 at 4:33 PM
    hueman562
    hueman562 Well-Known Member
    ken
    los angeles
    13 double cab LB 4x4
    yeah check your needle bearing, check your front drivers side inner axle, grab it and move it up and down if it has play your needle bearing has excessive play. theres a company called east coast gear and supply. they make a low friction bushing that fixes that problem, just buy the removal and install tools, makes the job so much easier.
  20. Apr 24, 2017 at 8:04 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Is it like a chugging noise?
