SOS Concepts 05+ rear bumpers
Discussion in 'SOS Offroad Concepts' started by SOS CONCEPTS, Jul 21, 2014.
  1. Jul 21, 2014 at 11:23 AM
    SOS CONCEPTS
    SOS CONCEPTS [OP] Bumper builder Vendor
    Eddy
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
  2. Jul 21, 2014 at 1:09 PM
    slcsez2000
    slcsez2000 Simon SEZ
    Simon
    Jacksonville, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Plasti Dipped emblems -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler with TRD exhaust tip. Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    HOW DID I MISS THIS PAGE?....I WANT ONE WITH HC!!!!
  3. Jul 21, 2014 at 1:18 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    Installing the rear HC
    Unbolt the factory hardware with a 17mm wrench. The most forward bolt on either side can be left in just a few turns so the new bumper can rest on it. Most factory rears are pretty hard to get off and you will most likely need help for the removal and install of the new one.
    Run a couple layers of painters tape across the bedsides then
    Measure down from the top of the plastic bedside to 1/4" below the break light. Slide the straight edge down towards the plastic fender and measure the same there. Use a straight edge ruler/lever to draw the line that you will cut with a fine tip marker or pin.. (I use my digital level to match the line I drawn with the top of the bedsides) depending on how comfortable you are cutting you can leave the fender flairs on or take them off to make the cut. PS we took them off and left the DS on.
    After drawling your line for the cut check it and make sure you're happy with it. (Measure twice cut once.)
    Remove the rear break lights useing a 10mm wrench and set them on the tail gate. You'll need to cut underneath them.
    Once done say a prayer and cut away :)
    Repeat on the other side.. Clean up on the back side of where you cut the sheet metal. Get help. Raise the bumper up and set on the two bolts so you can place the brace against the frame plates and run the bolts in. Fairly tighten them down on either side. There is some play in the pre cut holes on the mounting that you can raise or lower if needed.
    MurkedYota, mcharfauros and scottalot like this.
  4. Jul 21, 2014 at 1:19 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    +1
    Have you tried making anything high clearance yet?
    I'll donate you my truck if you're afraid of cutting yours :cool: :anonymous:
  5. Jul 21, 2014 at 1:20 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    I have a pic of one and this is LIVE
  6. Jul 21, 2014 at 1:21 PM
    slcsez2000
    Simon
    Jacksonville, FL
    12 TRD Sport 4x4
    I didn't see that new bumper up top. Looks sick with the recessed spot for the lights and plate. Once the front one gets prototyped up for the 2012+ I want the front and rear one like in the first pic with the high clearance sides and reverse light cut outs. That bumper is looking real good. Nice job.:cool:
  7. Jul 21, 2014 at 1:24 PM
    FIRE74
    FIRE74 Well-Known Member
    Corey
    St.Leonard, MD
    2012 DCSB
    Very interested Eddy, with swing out spare and a dual can mount on other side, I don't know how I missed this! :facepalm:
    scott96929 and Kanebutler13 like this.
  8. Jul 21, 2014 at 1:25 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    I made it for you fire
  9. Jul 21, 2014 at 1:29 PM
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    Send me a cost figure :D
  10. Jul 21, 2014 at 1:30 PM
    drunktaco
    Sage
    Southwest Va
    That looks nice. I know what I'm getting next haha
  11. Jul 21, 2014 at 2:19 PM
    Hard Luck GraphiX
    Hard Luck GraphiX Well-Known Member
    Josh
    SC
    2011 TRD Offroad
    2.5" Lift , Pro Comp 7031 Wheels , Super Swamper Thornbirds , TRD Sport hood , TRD Sport Mirrors , Color Matched Satoshi Grille , SOS Front Bumper , 20" LED Light Bar , SOS Rear Bumper , Roof Rack ,
    How much is a bumper like SGTCaps , I don't need no swing out or a high clearance bumper
  12. Jul 21, 2014 at 2:33 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
  13. Aug 1, 2014 at 7:14 PM
    Red Demon
    Red Demon Well-Known Member
    Vinnie
    Kennett Missouri
    07 SR5 4x4
    Tinted windows Upgrade to New 2014 radio Weather Tech Front Lift:2.5 ICON Extended Travel Coilover Shocks Icon Uni Ball Tubular UCA Rear Lift: Icon 1.5" AAL ICON 2.0 Aluminum Series Rear Shock Relentless Front Bumper Relentless Rear Bumper SOS Sliders and skid plate
    Is that $550 for it all ?:eek:
  14. Aug 1, 2014 at 8:05 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    $550 for the reg rear
    reg rear with swing out $900
  15. Aug 2, 2014 at 6:26 AM
    Red Demon
    Vinnie
    Kennett Missouri
    07 SR5 4x4
    Wish I had know about your bumpers before I ordered mine somewhere else :(
  16. Aug 2, 2014 at 6:31 AM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    Damn you gonna have the fastest build
  17. Aug 3, 2014 at 12:51 PM
    LINCOLN45
    LINCOLN45 Well-Known Member
    john
    sac
    2014 TACOMA DCSB
    265/70/17 TOYO OC AT Bilstein 6112 Coil and Strut Combo Tacoma Stealth 32" LED SOS SKID PLATES AND SLIDERS RIGID LED FOG LIGHT UPGRADE
    using factory hitch with this bumper?:confused:
  18. Aug 3, 2014 at 1:01 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Hopefully I'll be placing an order with you soon.
  19. Aug 3, 2014 at 5:54 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    reg rear still uses FACTORY hitch
    :D
  20. Aug 15, 2014 at 6:43 PM
    SOS CONCEPTS
    Eddy
    Laurens SC
    Rock bouncer
    I have the good pics. Robert was busy wiring :)
