SOS Concepts Bolt on Slider Installation Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beeraddict, Oct 18, 2016.
  1. Oct 18, 2016 at 2:49 PM
    beeraddict
    beeraddict [OP] Member
    N. FL
    4WD
    Evening,
    I just received the SOS Concepts bolt on sliders for my 2013, single cab, 4x4. Six holes on the mounting plates of the sliders look like they line up with 6 holes on the frame however, the front two holes (nearest to the front end) on the truck frame do not go all the way through the frame. I've contacted Eddy who makes them and he wants a picture showing the problem but, do to work haven't had time yet to respond. I sure wasn't wanting to do any drilling into the frame which was the reason for going with these sliders. Anyone else had this problem? Really considering welding them on instead.
  2. Oct 18, 2016 at 3:31 PM
    EHam
    EHam Well-Known Member
    Eric
    Charlotte, NC
    2011 DCSB TRD Off-road
    Never seen the frame of a regular cab but the 2 front holes do not go all the way through my DC either (the boxed part of the frame). You have to stick your arm up through there with the wrench
    DrFunker, Flying_Taco and Jeffvt0508 like this.
  3. Oct 18, 2016 at 4:14 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This.
    You gotta reach way up in there. Easiest to put the bolt through the inside of the frame and put the nut on the outside of the slider plate.
    REDdawn6 and Jeffvt0508 like this.
  4. Oct 18, 2016 at 6:08 PM
    beeraddict
    N. FL
    4WD
    Thanks very much to you both for the advice. I'll be getting under there tomorrow to see what you are talking about.
  5. Oct 19, 2016 at 5:01 AM
    Flying_Taco
    Flying_Taco "In there"
    James
    Tacoma, WA
    2014 TRD OR
    I found it easiest to lay with my head towards the front of the truck and reach up into the frame. Be careful when moving the brake line bracket. Those sliders are legit BTW!
    DrFunker likes this.
  6. Oct 20, 2016 at 7:04 AM
    beeraddict
    N. FL
    4WD
    Thankyou for the info. I took a look at it yesterday, and believe it's doable getting those bolts in those very front holes on the frame (both sides) however, don't have a clue as to how to keep the bolt from falling back down into the "cavity" when I go to mount the slider. Seems you would need pretty long arms to hold a wrench on the bolts head against the frame while getting the slider onto it (??). Or, will supporting the slider against the frame with holes aligned allow me to keep from losing the bolts since there would be no lifting and holding the slider in place. All I have is the truck's factory jack.
  7. Oct 20, 2016 at 7:07 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I wouldn't be doing any install with a factory jack.
    Maybe you should see if a local is willing to help, if nothing else, maybe a pair of cheap jack stands will give you more effective aid.
    R0dzilla75 likes this.
  8. Oct 20, 2016 at 7:14 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Some vendors will weld a piece of flat bar to the head of the bolt to facilitate getting it into the boxed section and holding it in place. You might try doing the same. Epoxy *might* work.
  9. Oct 20, 2016 at 9:54 AM
    Flying_Taco
    James
    Tacoma, WA
    2014 TRD OR
    However you get the slider into position, the middle bolts will at least take the weight for the time it takes to finish the rest of the bolts. I was able to put a crescent wrench on the nut inside the frame and use the frame itself to hold it while I used a ratchet from the outside.
    DrFunker and T4RFTMFW like this.
  10. Oct 20, 2016 at 10:33 AM
    beeraddict
    N. FL
    4WD
    Thanks for the tip James. By the way, How did you remount that little plastic brake lines separator when it has to be removed along with that little metal bracket that screws into the frame before placing the sliders mounting plate up against the frame?
  11. Oct 20, 2016 at 10:35 AM
    beeraddict
    N. FL
    4WD
    Please keep in mind, I'm talking about on the driver's side.
  12. Oct 20, 2016 at 12:17 PM
    Harry
    Santa Fe NM
    I wasn't able to remount mine (different sliders, same problem). I ended up relocating the lines slightly up and gluing the bracket to the frame. You also want to watch out for clearance issues between the lines and the slider bolts. I taped the bolts and the lines in case to protect the line if they began to rub.
  13. Oct 20, 2016 at 12:48 PM
    nd4spdbh
    SoCal
    Like i said earlier.
    On the driver side, put the bolts out through the frame, nuts on the outsize of the slider plate. This will help with clearances of the brake lines and getting things tightened easier as its much easier to hold onto a bolt up in the frame then spin a nut on.
    Flying_Taco likes this.
  14. Oct 20, 2016 at 2:54 PM
    Flying_Taco
    James
    Tacoma, WA
    2014 TRD OR
    I think I was able to relocate the plastic bracket to a different spot, there's also a good chance I broke it too. I'll try to snap a picture tonight or tomorrow. As for the bolts, I went from the inside on a few just like nd4spdbh suggested. I also put some fuel line over the brake lines where it contacts the bolt head. Almost two years with no issues yet.
  15. Oct 21, 2016 at 12:18 PM
    beeraddict
    N. FL
    4WD
  16. Oct 21, 2016 at 12:22 PM
    beeraddict
    N. FL
    4WD
    Man, you're right about that jack. Won't be using that flimsy looking tool this weekend. At any rate, think I'm ready to tackle putting the sliders on this weekend thanks to all the help you guys offered. For me, I'll mostly likely make it harder than it should be but, at least I've got some good instruction to go on. Thanks again.
  17. Oct 21, 2016 at 12:30 PM
    Old School
    Old School You are ignoring covfefe by this member.
  18. Oct 21, 2016 at 12:51 PM
    DrFunker
    DrFunker Well-Known Member
    Old School likes this.
  19. Oct 25, 2016 at 7:48 AM
    beeraddict
    N. FL
    4WD
    Well, I spent a good while this past Sunday, on the driver's side alone trying to bolt these sliders on. Got the 4 hardest ones first then came across a glaring problem. One of the holes in the slider plate is so close to the weld on one of the support columns, there is no way of even placing a nut on a bolt without hitting the column much less one of the supplied washers(???). The passenger side slider looks to have the same problem although I haven't lined it up yet to see. I'm currently waiting on a response from Eddy, as to what I should do. It makes me wonder if anybody is putting these bolt on sliders on a single cab truck. Maybe Eddy is more experienced at manufacturing these for double or access cab trucks?
  20. Oct 25, 2016 at 8:16 AM
    nd4spdbh
    SoCal
    I had a few holes that were close to the supports that might of had to bend up the lip of a washer but nothing to the point where i couldnt bolt everything down.
