SOS Toyota Tacoma 2012
Discussion in 'New Members' started by Wpxjacampos, Jun 7, 2016.
  1. Jun 7, 2016 at 7:02 PM
    Wpxjacampos
    Wpxjacampos [OP] Active Member
    jesus
    Toyota tacoma 1995 2.4L
    Hi group thanks for letting me join hopefully I can get good advice and feedback advice also.
    I have a Toyota Tacoma 2012 4.0 engine that recently got In to crash, the steering wheel airbag and seal belt pretensioner was blown.
    I put 2 resistor with 2.2 ohms to bypass the airbag but the airbag bag light still ON!
    Does anybody know what resistance should I have on the Steering wheel airbag??
    Also I bypass the seat belt pretensioner with a 2.2 ohms resistor after this I scan the airbag with the scanner tool and all the modules and all airbag seems to be working ok (no codes are seenon the scan tool);but the Airbag light on the dash is still ON can someone advice me if I am missing some connection?? or share any ideas???
    Appreciate the support.
  2. Jun 7, 2016 at 7:42 PM
    Joe D
    Joe D .
    I can't provide input on your question.
    But I do have one for you.
    Did you or do you plan to actually install replacements for the airbag(s) & pre tension device?
  3. Jun 8, 2016 at 9:00 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome to the club!:thumbsup:Good luck with what you need to square away!:fingerscrossed:I'm of no help in regards but you can always post in the 2nd gen.section of the forum to potentially get some more responses and help!
  4. Jun 8, 2016 at 9:05 AM
    Large
    Large Red
    Does the light blink then stay on or when the truck is running the comes on solid and stays on?
    Also did you replace the sensors on the crash bar?
  5. Jun 11, 2016 at 1:06 PM
    Wpxjacampos
    jesus
    Yes i replace the airbags already
    Joe D[QUOTED] likes this.
  6. Jun 11, 2016 at 1:07 PM
    Wpxjacampos
    jesus
    I send the airbag sensor to be reset can i still the car with out the Airbag sensor??
