Sould I take my 2006 to dealer for floor mat recall?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, Sep 12, 2011.
  1. Sep 12, 2011 at 11:12 AM
    saugus
    saugus [OP] Well-Known Member
    I checked my vin with the dealer site and it popped up. Just wondering if it will be worth my time. What do they do?
  2. Sep 12, 2011 at 11:18 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I would (and did.) I'm surprised you never got the recall notice. The brake over-ride thing they do is worth it in my opinion.
  3. Sep 12, 2011 at 11:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Cut your pedal and flash the ECU. Do they still zip tie the floor mats?
  4. Sep 12, 2011 at 11:48 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Screw that. They cover a stupid floor mat but don't cover a coil spring for the air bags. That's just stupid.
  5. Sep 12, 2011 at 11:53 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i did it.
    what the heck, i cant even tell. besides if it all goes crazy, and my truck gets possessed and slams me into a building..i dont want some junior lawyer to look up the fact that i ignored some stupid recall. i want my lawsuit to go smoothly in my favor,,just sayin.
  6. Sep 12, 2011 at 12:26 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    I wouldn't and haven't. I just don't trust the dealer messing with my truck and I have weather tech's so the mats itself aren't an issue.
  7. Sep 12, 2011 at 12:29 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have the OEM all-weather mats and they didnt replace them but they did replace the gas pedal, I believe its shorter.
  8. Sep 12, 2011 at 12:57 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    I wanted the logic upgrade but not the pedal cut. Unfortunately, they have to do both.
    I haven't noticed anything since they did it. Don't worry about it.
  9. Feb 3, 2013 at 3:39 PM
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    OK, so I ignored the recall when they came in.
    However, yesterday I'm pulling out of a parking lot, and the ignition starts accelerating, and I've got my foot on the break. I pressed harder and it seemed I was being pushed out into the main road of traffic. I saw I had time, and just went. A soon as I touched the gas pedal and took my foot off, it was back to normal.
    So now I'm thinking, if I don't have the recall done, even though its on actually a non-related issue, and I get into an accident and hurt some one, I'd be liable for not doing the recall.
    Also, I got the recall for the coil spring in the steering column which could cause the air bag to fail.
    I'm thinking of having both recalls done at the same time.
    I just have bad feeling about letting a dealer touch my truck which has 122,000 miles on it, but runs great otherwise.
    Do dealer mechanics sabotage older vehicles as a method of having the owner look at buying a new truck?
    I have my suspicions, especially years ago when I took a Ford F100 in for a tune up at a dealer, and couldn't even drive it out of the parking lot when I picked it up. They had all kinds of things messed up and the truck never ran right afterwards.
    Jim
  10. Feb 3, 2013 at 3:44 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    The mechanics really don't benefit from the car sales. They may tell you it needs so and so much work done,but no sabotage.
  11. Feb 3, 2013 at 8:49 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I didn't bother getting the recall done on mine, until the spiral cable failed which was covered under that recall. So, I caved, and got them both done at once. The cut pedal isn't an issue at all, and the reflash made a noticable improvement in how smoothly the engine idles, and it starts easier (cranked a bit long intermittantly) among other small things. Guys with automatics report better shifting after the reflash too. I say get it done.
  12. Feb 3, 2013 at 9:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I wouldn't make a special trip for it, but it's a good idea to have it done.
    They cut the pedal down and reprogram the computer to cut power when the throttle is at 1/3 or more and your foot is on the brake.
    I had mine done, if I wasn't looking for it, I would not know the pedal was modified. The same with the brake override, if I hadn't tried it, I'd never know it was there.
    Someday if you want to sell the truck, the subject of recalls may come up. It would be nice to point to the sticker under the hood and tell the buyer it's taken care of. Also, who knows, you or someone else may be driving the truck and have a true failure of the accelerator pedal or sensors, and the brake override may save the day.
  13. Feb 3, 2013 at 9:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    A mechanic makes his money performing repairs. There is no benefit to him if your vehicle starts running poorly after he's touched it. Either he will be blamed for causing a problem, or you'll get pissed and trade it in. No benefit to the mechanic either way.
    I'm an appliance repair tech. If I send a customer down the the sales department to buy a new fridge, I don't get a commission on that. I make more money patching the old one up than I do recommending a replacement. Sometimes it's the honest thing to do though.
  14. Feb 4, 2013 at 6:35 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I did because my original all weather mats cracked and I wanted the free mats. Not as good as the original all weather mats, but they were new and free. :cool:
  15. Feb 4, 2013 at 7:45 AM
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    Well, I scheduled an appointment to have both recalls done.
    BTW, I did a test today on the acceleration, in case it should it happen again. I just put my foot on the brake and turned off the engine. You still have brake power and steering, although hard.
    In my opinion its a faster response than trying to get into neutral first.
    The thing is, when this happened to me, I was on a gravel parking lot and as I applied my brakes at the exist, it accelerated. However, when I slammed on the brakes, the anti-lock brakes kicked in and the acceleration was moving me out into the main road. Luckily I had time to just get into my lane and tap the gas pedal, which cut the acceleration.
    Anyway, into the dealer on Thursday.
    Jim
  16. Feb 4, 2013 at 7:49 AM
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    joes06tacoma;
    Gee, the pedal is so small already and there is mega clearance around the floor mat, which is why I never bothered with the recall. I figured its just a gimmick to get you into the show room to look at new trucks.
    Yeah, I have a distrust for car dealers.
    OK the brake override is what convinced me to have it done.
    I'm retired and this is probably the last truck I'll ever own, so I want it running well as I take care of maintenance myself.
    Don't trust repair shops all that much either, but sometimes they're a necessary evil. :D
    Jim
  17. Feb 4, 2013 at 7:52 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    I guess it depends on the dealer. I told them to go ahead, but also that I don't want the pedal to be cut. Had to sign that I refused modification to the pedal. I have weathertechs since then also..
  18. Feb 6, 2013 at 3:16 PM
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    So I dropped off my truck today.
    I asked about the accelerator issue, and all they're gonna do is cut back the
    pedal and ensure that mats are secured.
    The dealership is 40 minutes away, and I hope I'm not sorry.
  19. Feb 7, 2013 at 10:45 AM
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    Done and they did reprogram the flash so the brake override.
    They also replace the coil in the steering column..
    Everything seems OK.
    Jim
