Sound at start up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FloridaCementTaco, Mar 14, 2022.
  1. Mar 14, 2022 at 4:23 PM
    FloridaCementTaco
    FloridaCementTaco [OP] Well-Known Member
    OEM running boards OEM bed lights OEM all-weather mats OEM chrome exhaust tip Gator soft, tri-fold tonneau cover 265/75/16 BFG KO2s Removed “chin strap” AC drain extension Rear differential breather extension Bilstein 5100 rear shocks Bilstein 5100 front height-adjustable shocks set at second height OEM tailgate remote lock
    I have a 2021 Tacoma with 8k miles. Since I got it new, it has been making a clunking noise (not too loud) from the front passenger side area. It’s only when I take off after the truck has been parked for a while - it does not make the noise when I drive, it does not make the noise when I turn, and it does not make the noise any other time - It only makes the noise when I take off after I have been parked for a while. Any ideas or similar experiences?
  2. Mar 14, 2022 at 4:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ABS check, maybe
  3. Mar 14, 2022 at 4:25 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Sounds like a brake pad sticking to the rotor no big deal.
  4. Mar 14, 2022 at 4:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    abs check. normal.
  5. Mar 14, 2022 at 4:34 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    ABS check or pad slap. All normal things, just annoying.
  6. Mar 14, 2022 at 4:38 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Trade in time.
  7. Mar 14, 2022 at 7:02 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Like others have said brake pads sticking. Pull pins and pads, lube with brake pad grease. It will stop the noise.
  8. Mar 14, 2022 at 7:05 PM
    koditten
    Kirk
    Central Michigan
    No. It's the ABS check.
  9. Mar 14, 2022 at 7:06 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    At 7mph its the abs check. Camrys do it. Sounds louder in some vehicles than others. Sounds like someone hit the side of the car with a stick.
  10. Mar 14, 2022 at 7:08 PM
    koditten
    Kirk
    Central Michigan
    2008 Tundra's and 2004 Tacoma's do it too.
    2016Tacoman likes this.
  11. Mar 14, 2022 at 7:19 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Mine does that as well. A weird sound. Hard to explain
  12. Apr 25, 2022 at 6:58 AM
    TRyanOC72
    TRyanOC72 Well-Known Member
    Tim
    2020 Tacoma SR5 4WD
    I have a 2020 SR5 and I'm experiencing the exact same noise and circumstances as you're describing. Passenger side, only after sitting all night. Slow roll about 10 feet, and then "clunk" coming from front passenger side. I feel better after reading this that it's normal.
    FloridaCementTaco[OP] likes this.
  13. Apr 25, 2022 at 7:27 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
  14. Apr 25, 2022 at 7:31 AM
    TRyanOC72
    Tim
    2020 Tacoma SR5 4WD
    TS4x4[QUOTED] likes this.
