sound coming from drive side front?!???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma09medic, Jan 23, 2014.
  1. Jan 23, 2014 at 6:02 AM
    tacoma09medic
    tacoma09medic [OP] ParaPUP09
    Tom
    Franklin
    2011 Taco, 4 inch lift, 315/70/17, all-pro armor front and rear, ARE Z series, bed lights, Tint, Rigid LEDS
    To much
    Ok, i had my spindles and bilsteins installed, and upped my tire size to 315/70/17.
    There is a sound that comes from my driver side front only, happens when turning or going straight. It isnt a constant thing it comes and goes.
    Could it be the new shocks and spindles are brand new and just need "breaking" in OR.is this something i should be very concerned about. The truck rides and drives amazing this is the only abnormality that i have found.
    Any input or things to look for would be very helpful. Thank you
  2. Jan 23, 2014 at 7:37 AM
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    Do you still have the problem when you go in to 4 wheel drive?
  3. Jan 23, 2014 at 7:43 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    he's a prerunner
  4. Jan 23, 2014 at 7:44 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    What does it sound like? A clunk? Like something is loose? a grinding or squealing?
  5. Jan 23, 2014 at 7:45 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    be nice if he said what the actual sound was
  6. Jan 23, 2014 at 7:47 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    Did you check to make sure everything is tight? Some here have had problems with loose cam bolts after the spindle install, resulting in a nasty popping sound when turning.
  7. Jan 23, 2014 at 8:04 AM
    tacoma09medic
    Tom
    Franklin
    To much
    Its like a squeeling...and ive only heard it a lower speeds, like when i come up to a stop light. Or when i was pulling up to the gas pump the other evening
  8. Jan 23, 2014 at 8:12 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Squealing means something is rubbing on a piece that is rotating. Look to see if something is touching the rotor.
  9. Jan 23, 2014 at 8:15 AM
    tacoma09medic
    Tom
    Franklin
    To much
    Only way i can describe it would be it sounds like when my ball joints where going out on my last truck..but i dont think thats the case here because its a yota with less than 100k miles...my last one had over 230k before i heard that
  10. Jan 23, 2014 at 8:28 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    Crawl underneath the truck and look for signs of rubbing. Are you running factory rims? If so are you running wheel spacers? You need spacers to clear those spindles with factory wheels or else they won't clear the spindle neck. That could be the metal on metal grinding you're hearing.
  11. Jan 23, 2014 at 8:28 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Might want to look at them, milleage will not dictate if you got a faulty part from the manufacturer. I got a bad, brand new in box, water pump from the dealer before.
  12. Jan 23, 2014 at 8:59 AM
    tacoma09medic
    Tom
    Franklin
    To much
    No im running 17" XD hoss wheels
  13. Jan 23, 2014 at 9:00 AM
    tacoma09medic
    Tom
    Franklin
    To much
    Im gonna look at the ball joints. But also gonna remove my swaybar..maybe that would help some of my issues.
  14. Jan 23, 2014 at 9:01 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Unless it's rubbing it shouldn
  15. Apr 2, 2014 at 4:44 PM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    What's the outcome on this? I too have the same squealing sound, or as if the brake pads are touching the disc as i drive at low speeds.
