Sound coming from engine bay with RPMs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Colbya48, May 9, 2023.
  1. May 9, 2023 at 8:19 PM
    Colbya48
    Colbya48 [OP] Member
    Colby
    2019 Voodoo Blue TRD Pro
    So I have noticed this sort of squealing/chirp sound that comes from the front of my truck (2019 v6) when I increase the RPMs where the sound also increases in volume. I can hear it in all gears including park and neutral. However I cannot hear it when the truck is idling, only when i increase the RPMs such as driving or revving the engine. My fan belt looks fine so I’m not sure what it could be. I only have 22k miles on it so the belts shouldn’t be giving out so soon
  2. May 9, 2023 at 8:36 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Chew, RustyGreen and Toyko Joe like this.
  3. May 10, 2023 at 11:10 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Probably the belt. I just changed my last weekend to fix the exact same problem. I'm at just under 50K miles.
  4. May 10, 2023 at 4:29 PM
    Colbya48
    Colby
    I just took it in and they said it was the belt AND pulleys. I somewhat doubt it’s the pulleys because of my low mileage even though the advisor told me the wear on the pulleys could be due to lack of driving which I have hard time believing
  5. May 10, 2023 at 6:58 PM
    RX1cobra
    19 OR
    I doubt the pulleys are bad too.
    shakerhood likes this.
  6. May 10, 2023 at 7:07 PM
    Colbya48
    Colby
    I’m thinking the same thing. They said the mechanic used a stethoscope and did a full check of the pulleys and belt (the belt was glazed) and it looks like they just want to replace all the pulleys plus the belt which is gonna run me $750. I’m gonna take it to a local mechanic later and get a second opinion
  7. May 10, 2023 at 8:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Take the belt off and spin the pulleys by hand. Listen for any noise
    Is there rust or something on the surface of the pulleys?
  8. May 11, 2023 at 7:12 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Any good mechanic would put the new belt on and test run it before any pulley is replaced unless the pulley is falling apart or obviously making a bearing noise. Love to see the book time on that to justify $750.
  9. May 11, 2023 at 8:34 PM
    Colbya48
    Colby
    That’s apparently what the mechanic reported, sound coming from the idler pulleys and belt, didn’t specify which ones just basically said all need to be replaced. He allegedly listened with a stethoscope but like everyone is saying there is no way all 3 pulleys are shot at 22k miles
  10. May 12, 2023 at 11:46 AM
    Gatafly
    Shawn
    Correct, he is trying to make more money thus he is NOT a good mechanic.
  11. May 12, 2023 at 11:52 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What did the other mechanic say?
  12. May 12, 2023 at 3:53 PM
    InfernoTacoCO
    InfernoTacoCO Well-Known Member
    Hannah
    Denver, CO
    2017 Inferno Orange Toyota Tacoma TRD Offroad
    Westcott Design 0° Sliders, Falken Wildpeak AT3’s, OTT Tune, Interior/Exterior LED lighting, Raptor Lights, WeBoost 4G-M Signal Boost Amp, Trail Grid Pro Front/Rear Anytime Camera, OEM Tailgate Actuator & Wiring, 20% Ceramic Tint.
    OTT tune. You’ll have a completely different truck!
  13. May 12, 2023 at 4:08 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Change the belt. Ya need to change the belt anyways. If the sound is still there then check the pulleys.
  14. May 12, 2023 at 5:12 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    I love when Toyota says “slight wobble of the idler pulley” is acceptable and normal.
