sound dampening for doors
Discussion in 'Audio & Video' started by tacomaman06, Jul 31, 2009.
  1. Jul 31, 2009 at 2:20 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    installing my new system tomorrow, and didnt have money for raam mat or dynamat......so i picked up 2 packs(6 in a pack) of these......
    http://www.goferauto.com/fbe-116.html
    what parts of the inner door are best to put the q pads?
  2. Jul 31, 2009 at 3:44 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    I'd put one behind where the speaker goes, three more centrally located on the largest panel. The remaining two I'd put on the inside panel to help reduce any resonance there. If you can't fit three on the inner surface, do two, and put three on the inside panel. Use any pieces you cut or trim off, you are just adding weight to the metal to change its resonance.
  3. Jul 31, 2009 at 3:51 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    X2!
    Any little bit helps! So if you have any left over mat left over, stick it up in the door! Don't waste any part of it.
  4. Jul 31, 2009 at 4:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok.....thanks for the responses.
    so..........can this stuff go over the vapor barrier instead of going inside the door and have the same effect? never done this kind of thing before(im more mechanical than anything else:)). all together...i have 12 sheets of it, so im hoping its enough for my 4 doors.
  5. Jul 31, 2009 at 7:49 PM
    KAPendley
    KAPendley Best Hack I Know
    Andy
    Hickory, NC
    96 2WD V6 Extended Cab
    Shaved, Lowered,Airbrushed (some)
    If you get a chance to do more, I HIGHLY recommend Second Skin. It is my sound deadener of choice and the only one I carried in my old store. Very reasonably priced and much thicker than Dynamat.
    http://www.secondskinaudio.com
    Not to mention Ant...the owner, is a GREAT guy!!
  6. Jul 31, 2009 at 8:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thanks for the heads up. this stuff that i got is actually around 3/16th's of an inch thick....should do pretty well i would think.
  7. Aug 2, 2009 at 9:04 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You know what works great? Get a role of foam tape from an HVAC/R supply or a hardware store and make a gasket between the outside of your speaker and the plastic ring on the inside of your door panel and that will do EXACTLY the same thing and cost practically nothing.
  8. Aug 2, 2009 at 9:09 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    if you are on a tight budget go to home depot or lowes and get some roofing stuff, it comes in a roll. Like Blue says you just want to change the resonance. From what I understand the idea of the raammat, second skin, and the other stuff is a take off from the original roofing product. Better than nothing, I think it is cheaper as well.
  9. Aug 2, 2009 at 9:31 AM
    KAPendley
    Andy
    Hickory, NC
    Roofing material is asphalt based. It is a HORRIBLE alternative because it will peel off. Eventually.
    Second skin, Dynamat, and others like that are Butyl based, so the adhesion is a 100 times greater!! I have used asphalt based deadener before, and learned from those mistakes.:D
  10. Aug 2, 2009 at 9:53 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    Peel and Seal is the roofing stuff. It works in a pinch, but as said, it will eventually delaminate. Also, there is some odor associated with it that is not present in butyl products.
  11. Aug 2, 2009 at 11:54 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  12. Aug 2, 2009 at 2:32 PM
    KAPendley
    Andy
    Hickory, NC
    Evercoat makes great products, so Im not knocking what you used at all Will. Please don't take my suggestions as saying what you used is shit. Hopefully it was not interpreted that way. Believe me, when it comes to a budget, noone understands like those that are unemployed...namely...me. LOL.:D
  13. Aug 2, 2009 at 3:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    none taken man.:D if i could have afforded second skin....i definitely woulda done that or raammat....but i think these q pads should work decently at least.
