Sound deadener - inside AND out of door?
Discussion in 'Mr Marv' started by Chickenmunga, Feb 28, 2009.
  1. Feb 28, 2009 at 11:07 AM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    i was looking at RAAMmat's install guide, and they put the mat on the inside of the door and the entire outside as well (see below), THEN put ensolite over that. Is this necessary or overkill? Can I just do the inside and then ensolite the outside?
  2. Apr 18, 2010 at 6:07 AM
    tunedx
    tunedx Well-Known Member
    X-Runner
    Is this overkill??????
  3. Apr 18, 2010 at 6:44 AM
    pwrstrk02
    pwrstrk02 Well-Known Member
    randy
    kansas city missouri
    2010 4x4,dc,off road, black pearl
    i was searching this last night and it wasn't too clear. how much do you need? is too much too much, or do you just need to do certain pannels?
  4. Apr 18, 2010 at 8:10 AM
    pwrstrk02
    randy
  5. Apr 18, 2010 at 8:40 AM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    '11 Tacoma TRD Sport
    3" lift
  6. Apr 18, 2010 at 8:49 AM
    zanodave
    zanodave Well-Known Member
    so il
    07speedwayblue
    I covered 100% of the outer door and in some places I doubled the deadener. on the inner door skin I did the tap on the metal test and then applied accordingly,and where the speaker goes I applied the deadener on the out side of inner door as much as I could. and then I used luxury liner pro on the outer door skin. along with a 12x12 inch of closed cell foam on the outer skin behind the speaker,along with covering inner skin 100% using ccf. IMO I don't think it is over kill,whoever I think their is a point of diminishing return. YOU will have to be your on judge on if it is over kill or not.
  7. Apr 19, 2010 at 12:17 AM
    Chickenmunga
    Keizer, Oregon
    When I did this last year, I discovered that I got so much that I may as well follow the guide. I ended up having enough left over that I did the rear wall and should have enough to do the rear doors - I haven't had the garage to finish.
    I've heard peel n' seal loses stickiness under high heat, but that's only from what I've read.
