Sound Deadener or Sound Barrier?
Discussion in 'Audio & Video' started by Joehs, Jul 6, 2010.
Deadener or Barrier?
Poll closed Aug 5, 2010.
  1. Deadener
    5 vote(s)
    83.3%
  2. Barrier
    1 vote(s)
    16.7%
  1. Jul 6, 2010 at 10:36 AM
    Joehs
    Joehs [OP] Okie!
    Joey
    Broken Arrow, OK
    12' Tacoma Sport
    Looking to gather the last of my stuff for my install. I haven't done a Tacoma before, so I thought I'd ask some of you guys here.
    The question isn't whether or not to use dampening material of some sort, it's which is the most effective treatment for our particular car. I have a 2008 DC.
    The two products I've been eyeing are the Cascade sound deadener, and the SecondSkin Proliner sound barrier.
    I know together, they would do wonders, but at the moment that's a bit out of my price range.
    So I turn to those of you who have taken this route, deadener or barrier? Why?
    I'll be looking to do all 4 doors, plus the rear firewall behind my enclosure.
  2. Jul 6, 2010 at 11:09 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    I'm not familiar with either of those, but I will always choose a constrained layer damper (deadener for your poll) to deal with resonance. Other noises (i.e. road noise, other vehicles, etc) can be tolerated. But to me, resonance and vibration are a no-no.
  3. Jul 6, 2010 at 11:58 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    It's like asking if you should use a hammer or a screw driver; each tool/product has a specific use. Some areas need to be deadened and some need noise treatment.
  4. Jul 6, 2010 at 1:08 PM
    Joehs
    Joehs [OP] Okie!
    Joey
    Broken Arrow, OK
    12' Tacoma Sport
    Right. This is more of a, if you had to choose one tool which would you choose, type of thing. Unfortunately, both tools at the moment are out of my price range, but one is affordable.
    Eventually, both will be used. For now, I have to decide on dampener first, or MLV first. I just can't quite decide which I think would be more worth the money as a stand alone, considering that together they would be much better.
  5. Jul 6, 2010 at 1:42 PM
    ItalynStylion
    Steven
    DFW, Tx.
    What is your "price range"? I'd find it hard to believe the stuff is out of your price range. If you plan to do the entire truck in it's completeness it will be expensive just because of the area covered. If you do parts of the truck it's not expensive at all.
    Case in point....the front doors need about 10 CLD tiles per door. 20x2.45 is $49. Noise barrier can come later. If you can't handle $49 then you probably should not be spending money on your truck.
  6. Jul 6, 2010 at 2:12 PM
    Joehs
    Joehs [OP] Okie!
    Joey
    Broken Arrow, OK
    12' Tacoma Sport
    I was hoping to get it done somewhere in the 150-200$ range. I hadn't even looked at SDS CLD tiles, which are quite affordable. If I could pick up 30 CLD tiles, do you think I would have enough to do both front doors / rear firewall of the truck? or would I need more in the range of 40 tiles? Even then, it's still well within my price range and I may be able to look into a noise barrier.
    I was looking at getting 2 of the Cascade door packs at 52$ a piece to get the front doors / rear firewall done. Which comes out to ~104, but luxury liner is pretty expensive at SS for 80$ @ 36sqft. Still, much closer to my budget range than I originally anticipated. Perhaps I clicked an incorrect link during my browsing earlier and looked at the Pro line.
    Any hindrance in only doing the front doors and not the rears? (Not planning on running a rear fill). Tiles are definitely getting ordered at that price.
  7. Jul 6, 2010 at 2:49 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I'd hit the rear wall with about 10 or so as well. More coverage is better but 25% is the point of diminishing returns. Remember, placement of them is crucial. Use the "tap test" to find which areas are resonant and then deaden those first.
    Only do the front doors unless you're a freak like me. I did the rear doors with both CLD and MLV/foam because I compete and needed the cabin of my truck to simulate stepping into another dimension.
  8. Jul 6, 2010 at 2:50 PM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    Personally, I hope you never get anything that stops the noise or deadens it.
    Why? Cuz I was in EMS for 10 years, and it's a serious PITA to be right behind some SOB with lights on, siren blaring, finger on the airhorn, and they're totally oblivious to you.
    My personal opinion is we A) need better/stronger/louder sirens, or B) a LOT less sound deadening in cars. Seeing how B isn't likely to happen, I wish the DOT would loosen up restrictions on sirens.
    Sorry... rant off.
  9. Jul 6, 2010 at 3:09 PM
    ItalynStylion
    Steven
    DFW, Tx.
    It bothers the crap outta me too. People keep going like it's no big deal and I'm going ape shit in my truck pulled all the way off the road. My car is DEAD quiet and I pull over for you guys because I CHECK MY MIRRORS REGULARLY. It's part of driving.
    Personally, I think you guys should be allowed to move people (by force) out of your way.
  10. Jul 6, 2010 at 5:08 PM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    I did a crew cab all doors, with Raamat BXT 2, it is 15x15 and used 9.25 sheets, inside and outside of the doors, so still have enough for back wall, roof and floor.
  11. Jul 8, 2010 at 6:09 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
