Sound deadening a 2019 Double Cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steve60, Nov 9, 2019.
  1. Nov 10, 2019 at 6:28 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Needs a layer of MLV now, OP. I’d go as far as putting a last layer of 1/16” neoprene over the MVL as a decoupling layer.
    I have all the stuff for mine, I just gotta find time to get it installed.
    mine will go completely top to bottom, left to right, like so:
    Body metal -> CLD -> CCF -> MLV -> neoprene -> interior panel/plastics
    I also have some open cell plugs another member made that fit right inside the cabin air vents. That should also help reduce some of that noise.
    If all else fails just turn up the music :notsure:
    Truc577, pudge151 and Steve60[OP] like this.
  2. Nov 10, 2019 at 9:26 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Good plan. Do it right or don't bother. You'll be happy you took the extra steps to do it right.
  3. Nov 10, 2019 at 9:29 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    +1 on the MLV
    It’s thick and a PITA to get the carpet and panels back on, but worth it.
    Rainoffire and pudge151 like this.
  4. Nov 11, 2019 at 4:11 AM
    Steve60
    Steve60 [OP] Well-Known Member
    Boerne TX
    2021 Red TRD OR 4x4 DCSB
    Thanks all for the MLV advice. That’ll go up next. Meanwhile, I’m thinking over some custom wood tool/storage boxes for behind the seats... Ease of access and maximized storage are what I’m after... any ideas appreciated...
  5. Nov 11, 2019 at 4:34 AM
    willee51
    willee51 willee51
    Bill
    Forest, VA
    2022 SR5 DCSB AT 4X4, 6-cyl MGM
  6. Nov 12, 2019 at 8:06 AM
    Steve60
    Boerne TX
    ICU1 I spent about 4 hours total as described in the original post
  7. Nov 12, 2019 at 4:13 PM
    willee51
    willee51 willee51
    Bill
    Forest, VA
  8. Nov 13, 2019 at 7:23 PM
    Steve60
    Boerne TX
    Still waiting on MLV, so don't have that added in yet. While waiting, I knocked together a couple experimental boxes that fit between the seatposts. All in all, about 6 more side-to-side inches of storage than with the factory panels, and about 2 inches deeper. Lost about 1/2 inch front-to-back from what the factory panels provided. Not sure yet whether I like this configuration. Have not figured out what to do with the additional vertical space (molle panel? a tray/shelf?).
  9. Nov 14, 2019 at 11:22 AM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    How does the sheets of sound deadening material compare to the roll or spray on stuff?
  10. Nov 14, 2019 at 11:56 AM
    Steve60
    Boerne TX
    I think sheets and rolls would be identical, assuming sheets were applied with 100% coverage. No idea about spray on...
  11. Nov 14, 2019 at 12:19 PM
    GoGoGadget
    2017 DCLB OR
    I meant roll on. Like paint. Since that would not have the overspray issues with spray on. Figured it would get in all the cracks and crevices better. Just don’t know if it absorbs sound as well.
  12. Dec 8, 2019 at 5:56 PM
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Looks good, how many square feet did you use?
  13. Dec 8, 2019 at 7:39 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    The boxes look to be a good start. I still don't know what all you want to store, but since the space gets progressively narrower one more row of boxes might be all that is effective. Above that, you might think about hanging tools. I'm not sure a molle system would work but it might. You might get some ideas from the following google search...
    https://tinyurl.com/uwo59ku
    Perhaps hanging tools separated (and sound-deadened) by foam might be possible. Kaizen foam comes to mind.
  14. Dec 9, 2019 at 10:33 AM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    I it takes about 10 sqft /door. Both shells.
    Yann[QUOTED] likes this.
  15. Dec 9, 2019 at 12:36 PM
    #35
    txranger83
    txranger83 Well-Known Member
    Colby
    Republic of Texas
    2020 Tacoma TRD Off Road
    so 40 sq. ft. for all doors? and would another 40 cover the roof, floor, and back wall?
  16. Dec 9, 2019 at 1:18 PM
    #36
    Ted Steel
    Ted Steel Well-Known Member
    Ted
    NC
    2018 Cav Blue Pro 6MT, 2014 Baja (sold)
    Do you have a pic or link to those plugs? Sounds intriguing...
  17. Dec 9, 2019 at 3:34 PM
    #37
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Ted Steel[QUOTED] likes this.
  18. Dec 9, 2019 at 6:47 PM
    #38
    Ted Steel
    Ted
    NC
    That is badass. Do those cabin vents let a bunch of noise in otherwise? Never thought of that but makes perfect sense.
  19. Dec 9, 2019 at 6:52 PM
    #39
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    i haven’t installed mine yet; but he says they work great. I’ll probably put a dab of hot glue on mine to keep them in place as I have plans for two subwoofers behind the seats.
