Sound Deadening Doors with RAAM Audio Products
Discussion in 'Audio & Video' started by fletch97, Feb 19, 2013.
  1. Mar 28, 2013 at 5:18 AM
    CrazyDiamond
    CrazyDiamond Active Member
    2011 4x4 TRD / DC / SB
    For future reference, you can use rubber cement as well. Super glue is not ductile (doesn't bend). Rubber cement allows for some flex where the cone meets the surround. I've put a screwdriver through a sub surround before, and the rubber cement held up to many years of abuse.
  2. Apr 28, 2013 at 7:14 AM
    fletch97
    fletch97 [OP] Well-Known Member
    NJ
    2020 Tacoma TRD Sport
    OK....so I finally got my box from Mr. Marv and managed to finish the installation. Here are some pictures of that installation....
  3. May 29, 2013 at 7:17 PM
    ike3000
    ike3000 Well-Known Member
    is that a HAT I10SW? how do you like it?
  4. May 30, 2013 at 9:21 AM
    fletch97
    NJ
    HAT I10SW? Not sure what that is.
  5. May 30, 2013 at 11:13 AM
    ike3000
    it's a 10" subwoofer from Hybrid Audio Technologies. the inverted surround led me to believe that's what you have.
  6. May 30, 2013 at 12:08 PM
    fletch97
    NJ
    Doh!... Yes, I have the 10" Sub from Hybrid Audio inside a custom box by Mr Marv.
    It sounds great!
  7. May 30, 2013 at 12:13 PM
    ike3000
    nice! i was contemplating going with that, but after much research decided on the IDQ10. that hybrid sub is very efficient and should get loud with little power.
  8. May 30, 2013 at 1:32 PM
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    I have component speakers that I'm about to install. If the wires are run to a crossover and amp on the back wall of the truck, I can simply disconnect the harness going to the stock speakers, right?
    The component speakers are not wired directly to the Kenwood double DIN. They are wired to the crossover and then the amp goes to the head unit with RCA cables.
  9. May 30, 2013 at 5:17 PM
    ike3000
    yea, if you're going to wire the new speakers directly the crossover/amp, then you can just disconnect the stock speaker connections. wherever you end up disconnecting them (either in door or behind HU), i suggest you apply electrical tape (or equivalent) over the exposed wire so you don't accidentally short out the HU's speaker outputs.
  10. May 31, 2013 at 6:59 AM
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    So Package #1 from RAAM covered all 4 doors and you still had enough for the back wall? That's pretty impressive. Can you tell a significant difference in sound quality and exterior noise reduction? Worth the money for the deadener?
  11. May 31, 2013 at 7:09 AM
    fletch97
    NJ
    Yes, I had enough to do all 4 doors and the back wall. It made a huge difference in the sound and was very impressive. I've never done sound deadening before so I had no idea what to expect. No vibrations of the metal, all the sound is kept inside the truck, less road noise, etc.. (Very impressed!) I thought it was worth the money.
  12. May 31, 2013 at 7:20 AM
    Yaozer
    North Jersey
    Nice. So you only did the recessed metal parts on the back wall?
    BTW, where in NJ are you?
  13. May 31, 2013 at 8:02 AM
    fletch97
    NJ
    That's correct. I spoke to Mr Marv about it and he advised that it would be plenty to achieve my goal. Plus he mentioned that it would make the fit of the sub box tighter had I covered the entire back wall.
    I am in the South Brunswick area of central NJ.
  14. May 31, 2013 at 8:38 AM
    Yaozer
    North Jersey
    Did try to put the material inside the entire channel where you ran the cables, or only parts where it was open?
  15. May 31, 2013 at 1:52 PM
    #35
    fletch97
    NJ
    Only in areas that were open and easily accessible.
  16. Jun 14, 2013 at 11:40 AM
    #36
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Quick question I see where a 3 way speaker is not necessary for the front door speakers as there already is a factory tweeter is a 2 way ok??
  17. Jun 14, 2013 at 11:42 AM
    #37
    aubi1414
    Justin
    Pensacola, FL
  18. Jun 15, 2013 at 3:39 AM
    #38
    ike3000
    You will be fine with a 2 way and those jl speakers will do the trick. 3 way would definitely require some crazy modifications and will take a lot of time to tune. 2 way is much simpler and will give a you good sound.
  19. Jun 20, 2013 at 6:00 AM
    #39
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Did you have to call them to get the discount or was there someway to do it online? I want to do my doors and back wall for sure. I've also thought about doing something under the front seats but i'm not sure what all I would need.
    Curious what the MrMarv box cost you as well if you don't mind disclosing.
  20. Jun 20, 2013 at 10:29 AM
    #40
    fletch97
    NJ
    Yes, I had to call to get the discount.
    I've been told that the floor would be a waste of time and money. Focus on deadening the doors, back wall and possibly the roof. (That's what I've been told.)
    The cost of the box will vary depending on what you want, and what type of sub is going in there. Give him a call and he'll gladly offer some options and prices. (Very nice guy to work with and he knows his stuff!)
