Sound deadening mat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 02Duck, Mar 9, 2023.
  1. Mar 9, 2023 at 5:43 AM
    02Duck
    02Duck [OP] manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Maybe this is a strange question, but does anyone know or have had experience with sound deadening mats applied to paneling causing rust issues?
  2. Mar 9, 2023 at 6:00 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Mar 9, 2023 at 6:05 AM
    02Duck
  4. Mar 9, 2023 at 6:38 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Where is the rust?
    How long has the sound-deadening stuff been on? Who applied it?
    Have you had your third brake light assembly Campaign done?
    Do you have or had a factory or aftermarket roof rack?
    Do you have a sunroof?
    Stevie17 likes this.
  5. Mar 9, 2023 at 6:47 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It can rust if it you are sloppy with the application. Properly applied and directions followed, no, it doesn't rust.
    Its basically the same adhesion and coverage as paint, therefore don't skimp on the prep work.
    02Duck[OP], na8rboy and stftaco like this.
  6. Mar 9, 2023 at 7:55 AM
    02Duck
    I'm asking if anyone has experience with rust caused by sound deadening mats.
  7. Mar 9, 2023 at 7:57 AM
    02Duck
    That's what I'm thinking, but the prep and proper application for some of the places you see often used seems very difficult or impossible to do. So I'm wondering if anyone has experience with rust caused by the mats on their vehicle.
  8. Mar 9, 2023 at 8:03 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    The most likely and equally the most difficult areas for your question would be the rocker panels on your doors. Its too early to tell whether I have rust there, but I'm still confident that I won't. It was easy to thoroughly clean and dry the area, cut the mat down to manageable pieces, and get the roller in there to press out air bubbles. Its very doable. If you are considering it, dedicate more time than you think you'll need and be both patient and meticulous. It actually isnt difficult at all, its just a little more time consuming than a blind peel and stick.
    02Duck[QUOTED][OP] likes this.
  9. Mar 9, 2023 at 8:39 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    There is really only one way sound mat can cause rust, and its not the sound mat thats causing it.
    But when installed, people will cut it to fit with a blade, if its cut while its laying on the surface then the blade can and will cut the paint to bare metal. Over time this will rust. So when installing mat, you want to do all cutting outside of the car, then put the mat in.
    TacoGranny and 02Duck[OP] like this.
  10. Mar 9, 2023 at 8:45 AM
    02Duck
    Thanks for the info. Seems like there good be a solid benefit just don't want a long term issue.
    Appreciate your info.
  11. Mar 9, 2023 at 8:45 AM
    02Duck
    Good point. Thank you
  12. Mar 9, 2023 at 8:51 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    No known rust. Large percentage of interior is covered. Doors, back wall, most of floor and overhead is deadened. Truck is 9 YO, sound deadening 7-8 YO.
    02Duck[OP] likes this.
  13. Mar 9, 2023 at 8:52 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I really haven't heard of anybody having long term issues with it. And the benefits are huge. I think the mats do every bit as much towards improving sound as speakers do, if not more so.
