Sound from behind dash/engine when cold out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aarontaco13, Nov 10, 2019.
  1. Nov 10, 2019 at 12:20 PM
    aarontaco13
    aarontaco13 [OP] Member
    2013 Tacoma SR5 AC 4x4
    Hey guys,
    When the weather drops below 30F I've been hearing a weird sound behind the dash/left side of the engine when idling or at a stop light. The best way to describe it is it sounds almost like a fridge running but 5 times louder. One thing to mention is that when I start driving, it goes away until i come to another stop. Could there be air in the coolant system since it stops when I start driving? It's not a watery slosh noise like I've read on here, which makes me think it might something else, a heater core issue maybe or a noisey pump? Never had an issue in the summer either.
    Thanks
  2. Nov 10, 2019 at 12:24 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Welcome to TW!
    Do you have your defroster on when this is happening or is it regardless of what the ac/heater is doing?
  3. Nov 10, 2019 at 12:51 PM
    aarontaco13
    Thanks!
    Everything is usually off most of time, I've tried cranking the heat but not the AC yet. It's just weird as soon as I touch the gas, it stops. Could it be the brake booster?
  4. Nov 10, 2019 at 12:53 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Hmm, I'm not sure. I have a noise similar to that when my defroster is on, but I think it's just the condenser working or something.
  5. Nov 10, 2019 at 1:03 PM
    aarontaco13
    Weird, when I go out later I'll try to crank the defroster and AC and see if it changes anything
  6. Nov 10, 2019 at 1:04 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Coming from the engine bay, or interior?
  7. Nov 10, 2019 at 1:06 PM
    aarontaco13
    From the interior only
  8. Nov 10, 2019 at 1:10 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Well, that's strange...not many moving parts left of steering column.
    Have you stepped outside and opened the hood when this goes on?
  9. Nov 10, 2019 at 1:18 PM
    aarontaco13
    Right. Maybe its heater core?
  10. Nov 10, 2019 at 1:23 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Heater core has no moving parts....and its on the right side
  11. Nov 10, 2019 at 1:25 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Let's get our directions correct here...as your sitting in the driver side, the noise is right or left of the steering column.
  12. Nov 10, 2019 at 1:32 PM
    aarontaco13
    It sounds like its coming right behind column/speedo in the dash
  13. Nov 10, 2019 at 1:39 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Well that is interesting. Can't hear from under the hood outside?
  14. Nov 10, 2019 at 1:48 PM
    aarontaco13
    I tried once but all I heard was the taco tick lol. Another thing to mention just in case, I did a drain and fill a while back and followed the thread correctly using the AT Temp check mode. Could I have messed up the level somehow and its the tranny/torque converter making noise through the interior? It's just strange it stops when I start driving but comes back at idle...
  15. Nov 10, 2019 at 2:14 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Yes, it is strange. Not sure what to tell you here. Perhaps post a vid? ...although they are not always that useful.
  16. Nov 10, 2019 at 2:23 PM
    aarontaco13
    No worries man, my phone doesn't really pick up the sound. I'll try to pin point the noise better when I go out later. Thanks for your help though
  17. Nov 10, 2019 at 2:26 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    No problem...if you narrow it down, let us know!
  18. Nov 10, 2019 at 2:28 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    I have a vibration when I first start my truck also. Mainly the vibration is only when I’m backing up or creeping forward before it warms up. I haven’t pinpointed it yet but it sounds like it’s behind the glove box.
  19. Jun 17, 2024 at 7:38 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Did you ever pinpoint what this was for you? I have the same thing as well as does @Pjerdan .....any possible fix?
  20. Jun 17, 2024 at 8:21 AM
    Pjerdan
    Pjerdan “I do what I want”
    Philip
    Hebron KY
    2012 Tacoma 4x4 double cab (SR5 unfortunately)
    Working on it
    Mine is similar sometimes when I am stopped at a stop light with the truck in drive, I get a vibration or rattling sound from the right side firewall area. It can be rather loud at times. I was thinking maybe something to do with the torque converter because it goes away as soon a I start driving.
