Sound in Passenger door when power window goes up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, Sep 9, 2011.
  1. Sep 9, 2011 at 8:40 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    Has anyone had a problem with their power window in the passenger door when the window is going up that it makes a slight growling sound that sounds like it is catching something on the way up?
  2. Sep 9, 2011 at 8:52 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I didn't have a growl but rather more of a pop. I took the inside of the door panel off and discovered a loose screw that was potruding into the moving parts of the window. Once tightened the problem was resolved. Just a thought for you.
  3. Sep 10, 2011 at 2:51 PM
    CraigS
    CraigS Member
    Maryland
    11 4dr TRD Sport
    Get a can of spray silicone w/ the little red tube. Spray the window seal track that the glass rides in normally where you can see it. Then take that red tube and stick it into the track at the bottom of the glass and let it run down into the door trying to lube the track as far down as you can.hopefully this reduces the strain on the motor regulator and the noise is reduced.
  4. Sep 30, 2011 at 6:52 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    I am thinking about taking my door apart to look and see what is going on..... does anyone think there is a possiblity that the motor is going bad inside the door? I was thinking if it was... that the window would not go up at all....... maybe replacing the regulator? What does everyone else think?
  5. Sep 30, 2011 at 7:33 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    Mines been doing this for the 30k miles that I have owned my truck. I can live with the noise, as it doesn't seem to have any actual affect on the functionality of the window
  6. Oct 1, 2011 at 8:01 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
