Sound Ordinance
Discussion in 'Audio & Video' started by Crashwell, May 10, 2013.
  1. May 10, 2013 at 3:30 PM
    Crashwell
    Crashwell [OP] New Member
    Hi folks, I have a 2013 double cab and wonder if anyone has an opinion or experience with the Sound Ordinance B-8PT powered sub woofer that Crutchfield puts out. There's a nifty location spot behind the left rear seat of my Tacoma where it would fit perfectly and I wonder how it would sound there. Thanks
  2. May 10, 2013 at 3:32 PM
    Aw9d
    Aw9d That one guy
    I've never heard it but I've heard a lot of good reviews about it from other TW members.
  3. May 10, 2013 at 3:37 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Fits fine behind the left rear seat in a DC. Considering you're paying $150 for a sub, amp and enclosure, it's a pretty good buy. Will not hit the lowest lows, but if you tune it right it will put some thump in the bottom end.
  4. May 10, 2013 at 3:49 PM
    eric3187
    eric3187 Well-Known Member
    i bought one to put under the passenger seat. if you consider that location, it will not fit if you have the rear seat floor vents. if removed, it will fit though.
    it seemed well made when i opened the box up
  5. May 19, 2013 at 6:39 AM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    I have it and love it. As mentioned it is not a 12" pound your chest wake the neighbors super sub, but it does thump pretty well and definitely strengthens the bass. I installed it behind the passenger seat in the cubby and it works great.
  6. May 19, 2013 at 9:50 AM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    nice ! thats a good spot, I was debating on putting one under the seat but I like that spot aswell, dont have to worry about people kicking it. Do you get any rattle from the plastics back there ?
  7. May 19, 2013 at 12:09 PM
    2012SilverSport
    Guam
    No rattle whatsoever. I was good about padding and making it solid. I ran the wiring in a manner that it doesnt have anything to vibrate against and ran it through the wire loom to keep it tight. I have 2 young girls so didnt want to mount it under the seat and take the chance of them kicking it or pulling the wiring out etc.
  8. Mar 11, 2014 at 11:23 PM
    LittleLady808
    LittleLady808 Well-Known Member
    Kauai,Hawaii
    2013 Prerunner SR5 2.7l
    Hi guys, I was searching posts and came upon this thread. I am in search of a good space saving sub with amp and came across this sound ordinance sub from reading the forums. Now, I have some questions and I'm sure all you guys will be a lot of help. As for this sub, can it be hooked up to your speaker wires using a level output converter? And would the HU need to be removed to attach anything from this sub to it? I am trying to figure out a way that's the easiest possible way to add a little thump to my music. Thanks guys I appreciate your help. :)
  9. Mar 11, 2014 at 11:35 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Not sure about what parts you need to wire it to the stock HU, but there's two decent threads on here about it. One is a review about it and the other is titled magic sub or something along those lines. Use the search and it should pop up. There's info in those threads about the install.
  10. Mar 12, 2014 at 1:29 AM
    LittleLady808
    Kauai,Hawaii
    Ok, did a lot of searching and reading and my eyes are about to fall out of my head but I didn't come across anything saying the remote wire had to connect to the back of the HU. Do all of these sub/amps hook up the same? I'm asking because I know someone who just hooked up a sub and amp in his truck using some converter kit that tapped into his speaker wires for his install without touching the HU and he put his remote wire to some kind of power wire to have it turn on with the key. Anyway, I'm sorry if this subject is a beaten dog but I needed to make sure before I ordered it. Thanks again! :)
  11. Mar 12, 2014 at 4:36 AM
    Polymerhead
    Missouri
    Not that you asked for an opinion, and maybe the '13 has a better stock system, but if I had just put a SO sub in my truck, it would have still sounded like crap. If you only have $200 to spend, I'd drop $100 for a HU and $100 for a pair of 6x9s for the front before I spent $150 on a sub. Again - maybe Toyota has gotten better but my '10 had unbelievably terrible speakers in it. Adding more bass alone would not have made my experience any more enjoyable.
  12. Mar 12, 2014 at 4:41 AM
    Polymerhead
    Missouri
    Also, yes, you can tap into the speaker wires in serial but the instructions tell you that the performance won't be as good as using a sub output. And yes, you need to run a wire from the sub to ignition power somewhere so that it turns on and off with the truck. I hooked mine up completely the first time and it didn't work - the instructions are vague on the ignition power wire but I guess it's common sense. I was an audio noob when I installed my system, so it took some trial and error.
  13. Mar 12, 2014 at 12:33 PM
    LittleLady808
    Kauai,Hawaii
    I got all new Kicker speakers for the front and back to be installed and just wanted to have a little more of a thump when it's all installed that's why I went with that powered sub. I didn't want to change the HU, I wanted to keep the stock look.
  14. Mar 12, 2014 at 3:33 PM
    Polymerhead
    Missouri
    Cool. An amp will be absolutely required though. The HU won't power aftermarket speakers without one.
  15. Mar 14, 2014 at 1:39 AM
    LittleLady808
    Kauai,Hawaii
    I'm keeping my fingers crossed that everything will sound good when it's all installed. I won't have a amp on the rear kickers or the front for that matter. Only thing to have an amp will be the sub so I hope this all goes well!:rolleyes:
  16. Mar 14, 2014 at 3:25 AM
    Polymerhead
    Missouri
    I switched out the front speakers first in my truck - Alpine 6x9s. They had zero bass. Basically the stock HU turned them into mids. Unless Toyota has increased the internal amplification of the stock HU, aftermarket speakers alone are going to sound terrible. Again, mine is a '10 so maybe they made it more powerful with the entune update...
  17. Mar 15, 2014 at 2:59 PM
    LittleLady808
    Kauai,Hawaii
    How would I know if my stereo is an Entune? Sorry if that's a stupid question. :confused:
  18. Mar 15, 2014 at 3:04 PM
    Polymerhead
    Missouri
    Sorry, I don't know anything about the specs on the new trucks - I just know the HU is different, at least regarding the interface. I guess you can try it and see how it works. Let us know! Worst case is that you have to rip it apart & add an amp later.
