Sound System Upgrade Subwoofers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by XxAlexX, Dec 30, 2019.
  1. Dec 30, 2019 at 7:18 AM
    XxAlexX
    XxAlexX [OP] Active Member
    Alex
    MIAMI, FL
    2018 toyota tacoma SR5
    6.5" lift 20x10 Moto Metal Wheels 35" Nitto Ridge Grapplers
    Hello all,
    I am about to pull the trigger on a sound system upgrade for my 2018 double cab SR5.
    Will be going with a sub-woofer box behind the seats to install 3 full size 10's, I already have the shop to do the install and the guy to make the box for me. Has anyone done this setup yet? I have seen a lot of members going with single or dual and usually shallow mounts. The box being made for me has a mounting depth of 6" so i have plenty of space to get those full size 10's in there
  2. Dec 30, 2019 at 7:20 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
  3. Dec 30, 2019 at 9:36 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    I haven't seen 3 10's here before, but it should work depending on the air space needed and the subs you put together.
    I have a single 10 in a sealed box getting 500W or so and it rattles all the mirrors and doors if i want it to...with 3 10s, you sure as shit better Dynamat everything you can get access to.
  4. Dec 30, 2019 at 9:45 AM
    XxAlexX
    Alex
    MIAMI, FL
    yea for sure bro, imma have the shop do it I’ll make sure to let them know. What I’m going for is to be loud enough to be in a truck meet up and have the whole parking lot lit up. We’re doing all speakers so I want the bass to keep up with the sound level we’re doing either legion audio or sundown not sure yet
  5. Dec 30, 2019 at 11:12 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Not mine, but here is a nice triple 10 setup
  6. Dec 30, 2019 at 11:37 AM
    XxAlexX
    Alex
    MIAMI, FL
    Ok i need to know whos setup this is
    Giggity Reid likes this.
  7. Dec 30, 2019 at 11:40 AM
    captainsava559
    captainsava559 Well-Known Member
    Hernandez
    Madera ca
    2019 tacoma trd sport 4x4 LB
    6” pro comp lift Arkon Lincoln 20x12
    That’s clean! I have 2 10s but w a made box.
  8. Dec 30, 2019 at 11:42 AM
    5nahalf
    Erik
    Minnesota
    I only have the pictures of it, I found them on a instagram aggregation site, so there was no other info other than the pictures.
    Here is the other pic I have of the box.
    RianH15 and captainsava559 like this.
  9. Dec 30, 2019 at 12:06 PM
    XxAlexX
    Alex
    MIAMI, FL
    i wont be able to do a box like that but definately going with a similar setup just the subs are going to be sundown SA-10's. the air space per sub on the box im getting is .60 and the sundowns require .50 so im more then ok. just need to workout the mounting for the amps, might just put the mono for the subs in the cubby under the rear driver seat and then the 4 channel under the passenger seat.
    im looking at 750watt rms per sub
    so i need an amp to put out 2,250watt rms to cover the 3 subs
  10. Dec 30, 2019 at 12:14 PM
    5nahalf
    Erik
    Minnesota
    The passenger front seat has a metal bar that goes across the underside that prevents things from being mounted under it, the passenger rear seat cubby has the jack mounting there that would prevent a amp from being mounted there.
    You could just cut out the jack mount though.
    these trucks are a bit limited on amp mounting locations, you can mount a single amp under the drivers front seat, a smallish amp under the drivers rear seat, or if you get creative you can build your subwoofer box with a step up under it, that way you can slide the amps under the box.
  11. Dec 30, 2019 at 12:22 PM
    XxAlexX
    Alex
    MIAMI, FL
    actually i can get away with installing an amp under the passenger seat, i saw theres enough space there. the second location would be under the rear seat but the drivers side which is the small cubby, if the mono amp doesnt fit i can always remove the plastic under there and i wont have to worry about the other side where the jack is. if i cant manage to do that then ill just remove and clean up the jack area, either way i cant use that jack im lifted 6.5" with 35s on 20s
    captainsava559 likes this.
  12. Dec 30, 2019 at 12:24 PM
    GreyBaldTaco
    2019 F150 5.0
    Not really my thing but that's very nicely done.
  13. Dec 30, 2019 at 12:26 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Pic of your truck man. Its required for new members.
    ...not really. just like to look at truck pics!
    Skydvrr and captainsava559 like this.
  14. Dec 30, 2019 at 12:28 PM
    XxAlexX
    Alex
    MIAMI, FL
  15. Dec 30, 2019 at 12:29 PM
    Mitch76
    Mitch
    San Angelo, TX
    Nice truck man. I wish chicks would reply that fast when i asked for newds! :D
  16. Dec 30, 2019 at 12:30 PM
    5nahalf
    Erik
    Minnesota
    Yeah that jack is useless to you then. I tried to put some audio control acm amps under the passenger side, the seat didnt move because it hit the amps.... those amps are only 1.75 inches tall.
  17. Dec 30, 2019 at 12:31 PM
    Mitch76
    Mitch
    San Angelo, TX
    Can you use some of those seat spacers? Would they lift it up enough?
  18. Dec 30, 2019 at 12:31 PM
    XxAlexX
    Alex
    MIAMI, FL
    lol thx bro :rofl:
    i have rgb lighting all around just dont have any night pics.
    i think with 3 full size 10" subs ill make an impression with my truck, wont be expected lol:D
    Mitch76[QUOTED] likes this.
  19. Dec 30, 2019 at 12:31 PM
    5nahalf
    Erik
    Minnesota
    Yeah, I guess you could jack the seat up with some spacers.
  20. Dec 30, 2019 at 12:39 PM
    XxAlexX
    Alex
    MIAMI, FL
    I have heard of people using spacers for the seats but im not too fond of that, prefer to secure the seats correctly. by putting spacers the seats anchoring points lose alot of strength and if theres an accident it can be a big problem. ill make it work without that
