Sound system upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by delta7, Jun 9, 2021.
  1. Jun 9, 2021 at 10:40 AM
    delta7
    delta7 [OP] Delta7
    2020TRD SPORT PREMIUM
    not much left to do on my 2020 tacoma
    I have the jbl package in my 2020 tacoma and I installed aftermarket amp and sub. The sub is cutting out either when I turn the volume up and when I turn the bass up. If anyone has any ways to fix this I’d love your input. I’m by no means a car audio professional so if you could dumb it down a bit that would be great. Thanks in advance.
  2. Jun 9, 2021 at 10:44 AM
    YouKnowNB
    YouKnowNB Well-Known Member
    Nick
    Black TRD Offroad 4x4
    Sub could be blown and its separating at high volume. Any rattling before it cuts out?
  3. Jun 9, 2021 at 10:46 AM
    delta7
    delta7 [OP] Delta7
    It’s brand new.and no no rattling
  4. Jun 9, 2021 at 10:46 AM
    cardinalsfan
    cardinalsfan 2022 TRDOR DCLB
    I'll bet the amp is pulling too much power and cutting out. Had that happen with an old JBL GTO amp in my Saturn SC2 with a 100 amp alternator or something small. The amp was pulling too many amps and cutting out.
    Quick and dirty way to find out, what's the total amount of all of the fuses in the amp added up?
  5. Jun 9, 2021 at 10:48 AM
    delta7
    delta7 [OP] Delta7
    60 there’s two 30 fuses on the amp.
  6. Jun 9, 2021 at 10:49 AM
    delta7
    delta7 [OP] Delta7
    Can I fix this by getting higher volume fuses?
  7. Jun 9, 2021 at 10:52 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Did it just start doing it recently how long have you had the sub installed ? How is it installed ? Might want to try to adjust the gain on the amplifier .
    Evostaco and cardinalsfan like this.
  8. Jun 9, 2021 at 10:52 AM
    YouKnowNB
    Nick
    If fuses are not blowing then running a bigger fuse does nothing except run the risk of damaging amp. Might just be exceeding the nominal output of amp. Look and see if safety light comes on the amp.
    cardinalsfan likes this.
  9. Jun 9, 2021 at 10:53 AM
    GOTSAND?18
    stock
    No You can’t go higher fuses u will burn your amp .
  10. Jun 9, 2021 at 10:54 AM
    cardinalsfan
    Only if you wanna risk blowing the amp and doing damage to the electrical system of the truck.
    I don't know how many amps the stock JBL system is but let's say between 30-60. So 45, plus the 60 from yours is 105 on a truck with a 135 amp alternator.
    I'd start checking for voltage drop at low volumes and turning it up and seeing how it does and looking for idle drop or light dimming.
  11. Jun 9, 2021 at 10:54 AM
    cardinalsfan
    Also you'd be better off in a car audio forum as this isn't a Tacoma specific issue. You'll get more/better help I'd imagine.
  12. Jun 9, 2021 at 10:57 AM
    delta7
    delta7 [OP] Delta7
    Ok thanks I just installed it.
  13. Jun 9, 2021 at 11:58 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Could Ohms be an issue or gauge of wire?
  14. Jun 9, 2021 at 12:25 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Chances are the amp is going into protection mode due to over heating or over current. Check what ohm rating the subwoofer is rated at and compare it to what the amp can handle. Also keep in mind if its a 2 channel amp, and you have it bridged, then the load rating will be different than whats listed for 2 channel operation.
    a 2 channel amp thats rated at 2 ohms is usually only rated for 4 ohms when bridged.
    Tell us what your using and we can better tell you how to set it up. What we need -
    Amp model number
    Sub model number
    gauge wire you have running from the battery.
