Sound system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drjohn, Apr 2, 2016.
  1. May 30, 2016 at 5:30 PM
    #41
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
  2. May 30, 2016 at 5:33 PM
    #42
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    DrFunker likes this.
  3. May 30, 2016 at 5:35 PM
    #43
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    Cows Have Claws likes this.
  4. May 31, 2016 at 1:54 AM
    #44
    DrFunker
    DrFunker Well-Known Member
  5. Jun 2, 2016 at 5:01 PM
    #45
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Last time I saw rancid they performed it. So kick ass, hearing Tim sing it.
  6. Jul 25, 2016 at 8:59 AM
    #46
    Crash54
    Crash54 Member
    Tacoma
    TRD Sport
    Just an update, I did go with a 10 inch sub and a 5 channel amp. The sub had a custom enclosure made to fit behind the back seat drivers side storage compartment. After the sub's speaker was broken in. The sound has improved greatly. The factory speakers have had a marked improvement as well. But at some point I will be replacing those.
  7. Jul 25, 2016 at 1:29 PM
    #47
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    I know this is old, but while I think the JBL really sounds amazing and I wouldn't change it at all, I would have to say, I wouldn't push it as loud as you are wanting to....could it do it, probably, but I doubt the factory speakers themselves would be able to hold up at max volume for very long, and certainly not for the life of the vehicle, and if they do, it would be distorted. still my JBL kicks ass at 35-40 with the bass, mids, and treble at about +2, +1, +2. And The DSP definitely does a great job of smoothing out distortions at higher volumes, but normal speakers just can't handle MAX output
    cajuncowboy[QUOTED] likes this.
  8. Jul 25, 2016 at 4:04 PM
    #48
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    I have the JBL 2.0 package
  9. Jul 25, 2016 at 5:57 PM
    #49
    stevotivo12
    Stephen
    if you want to push it loud, don't opt for the JBL package and spend your money on good aftermarket components. You will end up spending about the same amount of money, maybe less if you don't need subs, but getting WAY better sound.
    Check ratings on the shop you take it to first to make sure its not a bunch of amateurs working there, and then once you have it installed take the time to set it up right!
    90% of the sound of your sound system overall is in tuning the components to work together correctly. Probably half of that 90% is simply in setting your crossover frequencies... If you take the time to set your crossover well then you can make any system sound much better and from there it will only be small, incremental improvements. The crossover setting can yield pretty dramatic results. Additionally, a good crossover setting will yield better all-around sound than a similar setup with an inaccurate or untouched crossover point
  10. Jul 25, 2016 at 6:19 PM
    #50
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
