Sound under dash?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO TX, Sep 7, 2013.
  1. Sep 7, 2013 at 3:43 AM
    TACO TX
    TACO TX [OP] Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    So im sitting here at work waiting for the gate to open up and i start hearing this noise from under the passenger side dash. It sounds like a actuator or motor opening and closing over and over. I put my hand down there and can feel that its coming from back behind the glove box area. What is back there that would be opening and closing? No A/C running or anything.
  2. Sep 7, 2013 at 5:14 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    It sounds like the recirc door actuator is acting up.
  3. Sep 7, 2013 at 5:42 AM
    TACO TX
    Kelly
    Denison ,Texas
    With everything off fresh air circulates so it should be open, correct. Then it closes when the A/C is on and no recirculate. Correct? Could it have a short in it i wonder?
  4. Sep 7, 2013 at 6:47 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If your defroster is on, then it would be turning the A/C compressor on and off to remove moisture.
  5. Sep 7, 2013 at 6:47 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    We replace these at Lexus all the time. The actuators go bad (internal short) and make all sorts of noise. The only way to be sure is to turn the key to on (A/C off) and look at the arm that connects to the actuator. If it's moving back and forth rapidly, the actuator is bad.
  6. Sep 7, 2013 at 7:06 AM
    TACO TX
    Kelly
    Denison ,Texas
    Ok ill look at it after work, when the truck was running and A/C off it would open then close, pause a sec and the do it again. Then stop for a bit and do it all over again. Sounds like it's tit's up to me. Thanks guys
