Soundman's Super Simple Speaker Stencils (3rd gen)
Discussion in 'Audio & Video' started by soundman98, Sep 4, 2022.
  1. Sep 4, 2022 at 4:50 PM
    soundman98
    soundman98 [OP] Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    do you like going against the grain?
    do you want to fit some speakers that aren't 6x9?
    do you wish someone would just post all the measurements and depths without being all cagey about "just take your own truck apart"?
    do you prefer to make your own adapters instead of best buy screwing it up for you?
    well these templates are for you!
    driver and passenger side speaker openings are mirror images of each other, simply flip the templates over for the opposite side.
    all pertinent information should be on the template, (+/- 1/2" for crash bar vertical location) , just print, check scale, and cut your new adapters to size from your favorite material!
    2 of the files are the jpeg versions, the pdf is both templates in 1 document. whichever prints better!
    happy building!
    edit: added dash tweeter layout. this is a direct trace of oem tweeters overall shape, anything a 1/4" larger will require cutting to the dashboard plastics under the grilles-- this is the primary constraint. even an extremely deep tweeter like the morel mdt39 will fit depth-wise with minor offsetting from the oem tweeter centerpoint.
    TreeFortRichard likes this.
  2. Sep 4, 2022 at 5:29 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Love these!
    Life could be so easy if people would just tell other people what they have learned
    soundman98[OP] likes this.
  3. Sep 11, 2022 at 10:35 AM
    No_Tread_
    No_Tread_ Well-Known Member
    Travis
    bump! - Badass dude, Thank you
    What did you end up installing?
  4. Sep 11, 2022 at 2:07 PM
    soundman98
    NW Indiana
    peerless 6.5" hds nomex midbasses that seem to work great in anything more solid than a soggy cardboard box, and some aiyima ring radiator tweeters that so far have made their presence known as visitors instead of companions.
