Soundproofed Roof - Now Compass Does Not Work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, Oct 8, 2011.
  1. Oct 8, 2011 at 1:49 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2010 Access Cab SR5 4x4 5 speed 2.7l
    Fog lights with OEM switch - Heated mirrors with OEM style switch - Cab sound deadening - Lighted 4x4 switch - URD short shifter - Rear backup camera - 2012 rear view mirror (compass, outdoor temperature and backup video mirror) - Heated seats - 2014 Tacoma stereo install - Bluetooth with OEM steering wheel controls, Access roll-up tonneau cover
    I soundproofed my roof with Rammat (foil and butyl) and then installed an OEM Toyota temperature/compass meter in the head console. The temperature works fine but the compass will not calibrate (I followed the instructions to a T). I then installed my buddies temp/compass unit and same problem.
    I'm wondering if the Rammat may be blocking the compass signal.
    Has anyone else who soundproofed their roof had this problem?
  2. Oct 8, 2011 at 2:56 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    I'm sure it is.. Foil has foiled you.
  3. Oct 8, 2011 at 10:08 PM
    Tunngavik
    Alberta, Canada
    So did this actually happen to you or are you just regaling me with bad puns?
