Sounds Coming from Driveshaft.. I think
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattypantsog, Mar 12, 2021.
  1. Mar 12, 2021 at 3:54 PM
    Mattypantsog
    Mattypantsog [OP] Member
    2015 red toyota tacoma base
    Like stated above. I have a 2015 tacoma, no lifts or anything have been done to her. When I got her I heard the sound but 4 months later and I'm cracking the window for air and I'm noticing for the first time how loud sounds outsidethe cab. Even when I'm hardly stepping on the gas she makes the noise and the noise only happens at about 5ish mph and then again at 20s and further into the 30s. Iv had her since November of 2020 and she currently has 37000 miles on her.
    The noise it's like medal vibrating werRRR sound.
    Any help is appreciated
  2. Mar 12, 2021 at 4:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    With 37k, I wound not suspect wheel bearing or the needle bearing yet.
    How long has it been since the U-joints were greased?
    Sounds are really hard to diagnose over the internet.
  3. Mar 12, 2021 at 5:15 PM
    Mattypantsog
    Yes my new challenge is downloading a video on here. Iv never greased them and I don't see specifically if the maintenance included greasing them. They look like dry u-joints to me but I'll have to double check in the morning
    I'll do my best to get a video up
  4. Mar 12, 2021 at 5:24 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    If the u joints are making noise greasing isn't the answer, replacement is.
    Mattypantsog[OP] likes this.
  5. Mar 12, 2021 at 5:30 PM
    CassND
    CassND Well-Known Member
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    One thing you may try is after a drive, take a temperature gun to each of the unjoint caps. If 1 cap is hotter than the others, that may be your problem.
    Something easy to try while you’re crawling under there anyway. :-/
  6. Mar 12, 2021 at 5:39 PM
    Mattypantsog
    Here's a video.
    Times to listen out for are
    00:05
    00:20
    00:24-27
    Lastly at 00:54 after a full stop
  7. Mar 12, 2021 at 5:45 PM
    TnShooter
    Deogee
    STOCK
    That doesn’t really sound a u-joint.
    That almost sounds like heat shield or something.
    Have you checked all the heat shields and guards under the truck?
  8. Mar 12, 2021 at 5:55 PM
    Mattypantsog
    Yes I checked the heat shields and guards. Made sure everything that's bolted in is tight
  9. Mar 12, 2021 at 6:23 PM
    Mattypantsog
    Thanks for the idea. I'll check that out
  10. Mar 13, 2021 at 4:30 AM
    CassND
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    Yup. I had a buddy to this and it worked for him.
  11. Mar 13, 2021 at 5:39 AM
    Mattypantsog
  12. Mar 13, 2021 at 11:33 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    This what I like about TW
    Many great minds put together to help others
