Sounds like 05 isn't shifting at highway speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by martin8479, Nov 17, 2011.
  1. Nov 17, 2011 at 5:16 PM
    martin8479
    martin8479 [OP] Member
    My 2005 4 DR 4x4 Tacoma (auto) sounds like it needs to shift when I approach 55-60 mph. RPMs are still low. Physically shifting doesn't cause sound to increase, and shifts normally. All passengers say "do you have it in the wrong gear".
  2. Nov 17, 2011 at 5:19 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    When was your last major service?
    My cousin's pickup truck did the same thing; all he needed was to service his vehicle as it was in poor running order.
    Tacoma equivalent would be to perform a full major service including all fluids and a transmission drain and fill.
  3. Nov 17, 2011 at 5:24 PM
    martin8479
    Thanks, never really serviced anything except engine oil, I'll give that a try.
  4. Nov 17, 2011 at 5:26 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    lol
  5. Nov 17, 2011 at 5:27 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
  6. Nov 17, 2011 at 11:50 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Spark plugs!
  7. Nov 18, 2011 at 12:54 AM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    X2
  8. Apr 14, 2012 at 4:23 PM
    NvrSumR
    NvrSumR Well-Known Member
    Jeff
    Colorado
    OP, not sure if you ever got the problem figured out or not. But if not, I had the exact same problem. Even people riding would ask if there is something wrong with the truck. So I took it into the dealer and had a Tech ride with me. He immediately said it was a wheel bearing. Came back to the dealer and they called me a couple hours later saying it was the front left wheel bearing. Luckily its under warranty for me, not a cheap fix.
  9. Apr 15, 2012 at 3:51 PM
    martin8479
    Thanks! I'll check the bearings right away. Mine's well out of warrenty. I haven't resolved it yet. I waited until the next oil change then changed plugs but that didn't do anything. Kind of thought it was my tires, as they are wearing out, but with even thread wear.
  10. Apr 15, 2012 at 3:53 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    umm how does a wheel bearing affect transmission shifting?...
  11. Apr 15, 2012 at 7:21 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    He is referring to the noise a bearing makes as speed increases.
    He mentions engine rpms are low but vehicle is at highway speed and it questioning the reason for the high rpm type of sound.
    Since you have a 4wd truck you have a number of bearing up front that could be causing the noise as speeds increase. Could also try putting it in 4wd hi to see if the sound changes at all. Might help a tech pinpoint the issue.
    If it is a wheel bearing typically when making a turn you can hear the noise as well generally only one direction as it is only one failing bearing. Since you are putting added load on the bearing when turning.
  12. Apr 19, 2012 at 10:39 AM
    martin8479
    I checked in 4wd yesterday, no noticeable change. About turning, the noise disappears when in a tight right turn, even at low speeds (around 30). When turning, the "high rpm type" sound stops completely. I was even wondering if its my tires. I put the near new spare on the passengers front and the noise didn't change at all. Thanks for the posts.
  13. Apr 19, 2012 at 10:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd guess wheel bearings or brakes.
  14. Apr 21, 2012 at 8:15 PM
    NvrSumR
    Jeff
    Colorado
    I thought it was the same thing. The problem sounds like the transmission wasn't shifting into it's highest gear; like you are driving in 3rd or 4th gear on the highway. But the RPMs remain normal. I had a master technician ride with me and he determined it was a wheel bearing before even looking at one. Turns our he was 100% correct.
  15. Apr 28, 2012 at 10:36 AM
    martin8479
    Just to close this out, I took it a local shop and they replaced the drivers front wheel bearing, $355 ($100 parts, $255 labor).
