sounds like a bearing???
Discussion in '1st Gen. Tacomas (1995-2004)' started by tt07, Oct 20, 2010.
  1. Oct 20, 2010 at 5:55 PM
    tt07
    tt07 [OP] Well-Known Member
    north carolina
    01 4wd
    none yet
    I need everyones help i have a 01 4wd ext cab and about 25-35mph i have a bearing noise somewhere but it sounds like it coming from the rearend!! When you put a trailer behind it with a little weight its worse!! I have had it on the lift and we have tried to figure it out but just nothing concrete yet. I have a some extra play in the pinion but just dont KNOW!!! HELP PLEASE
  2. Oct 20, 2010 at 7:24 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    more than likely you have a rear wheel bearing going out. if you can get a hold of some chassis ears you can tell which one. if not raise it up and put a screwdriver to each wheel and then put your ear to it.
  3. Oct 21, 2010 at 4:33 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Probably just a rear wheel bearing! I had one of mine go out because my axle seal blew! Not hard al all to change just pull of the wheel and tire, brake and then there are 4 bolts on the backside of the brake housing holding the axle on! Remove these bolts and pull the axle out and there you go!
  4. Oct 21, 2010 at 8:00 AM
    tt07
    north carolina
    01 4wd
    none yet
    oh and when i go into a right curve it quits and going straight and left curves still there!! Thanks
  5. Oct 21, 2010 at 10:49 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I'll bet a dollar that it is a axle bearing.. the right curve turn puts the bearing balls/rollers away from the screwed up side of the bearing, hence the noise goes away. usually the constantly dirty side (outside) of the bearing goes out first, and then it takes the rest out rapidly. those are delicate surfaces in there and once they get scratched or gall,,,game over.
    Pinion bearing would be a constant annoying growl, off power or on,,and only get worse as the pinion gear takes out the ring gear,,yikes.
  6. Oct 21, 2010 at 6:18 PM
    tt07
    north carolina
    01 4wd
    none yet
    so which side would you think it is??
  7. Oct 22, 2010 at 10:24 AM
    Mod
    CR, WA
    stock
    Is one side or the other loosing gear oil?? (leaking seal).
    If not,,,you will have to get the truck up on jackstands(reguardless),,put it in neutral, remove the brake drums (and possibly front rotors) and spin hubs and axles so you can listen and feel. slightly pushing in and turning very slowly will take the slack out of the bearing and allow you to feel the grittyness,,might needs to pull on said hubs and axles and do the same.
    It's a tough gig trying to find a bad axle drive bearing,,unless the thing explodes or starts shaving off visible metal somewhere,,,like on the backing plate behind the brake shoes.
    So which side would I check first?? I would check the right side,, on the average it takes more outside side load due to the crown of the highway/road. (just a starting point)
  8. Oct 22, 2010 at 10:39 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Replace them both if you replace them.
  9. Oct 23, 2010 at 7:38 PM
    tt07
    north carolina
    01 4wd
    none yet
    Thanks for the info!! I think i will do them both at the same time bearings and all seals. Thanks again!!!!!
  10. Oct 24, 2010 at 5:15 PM
    tt07
    north carolina
    01 4wd
    none yet
    ok today i put it in 4wd and it want do it???? SO WHAT NOW
  11. Oct 24, 2010 at 7:05 PM
    Mod
    CR, WA
    stock
    When you tested it in 4wd, did you have it on Jackstands/rack? or on highway?. the 4wd might have been masking it.
  12. Oct 25, 2010 at 5:46 PM
    tt07
    north carolina
    01 4wd
    none yet
    I was driving down the road. any sugg??
  13. Oct 25, 2010 at 6:53 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Im having a very similiar problem. I have squeking coming from what sounds like the rear right wheel, but only when going from 0-10mph and it stops. Just greased the driveline and recently had the brakes serviced so neither of those would be the problem. I think it may have something to do with driving in water. We had some thudnerstorms down here in Arizona a few weeks ago and the streets were flooded. I popped it and 4WD and charging through the water. I wonder if the water pressure cleaned out the grease.
    My question is this. Is it possible to re-grease a wheel bearing or should I just plan on replacing them. is $90 the avg price for one?
  14. Oct 26, 2010 at 5:47 PM
    tt07
    north carolina
    01 4wd
    none yet
    I know you cant grease them they are sealed so you will have to replace them!! Im just having a problem figuring out EXACTLY where its coming from because i dont want to replace parts for NOTHING!!!!!!!!!!!
