sounds like a belt squealing
Discussion in 'Technical Chat' started by DubVtundy, Oct 6, 2011.
  1. Oct 6, 2011 at 7:45 PM
    DubVtundy
    DubVtundy [OP] ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    ok mods dont know where to put this but move it where it needs to be plz. but my problem is i have a squealing noise coming from my truck that sounds like a belt squealing. i know its not the belt bcz i can put my truck in neutral and turn the truck off and drift it and it still is making this noise. i was hoping that it would be maybe a brake pad sticking so i changed the brake pads and it still does it. so then i thought maybe that the drive shaft needed some grease, put some in it and still squealing. does anyone know of what this could be or has anyone ever had this problem? i am totally stumped and so is my mechanic, we have no idea what this could be? someone plz help
  2. Oct 6, 2011 at 8:16 PM
    DubVtundy
    Thayer
    bump someone plz help
  3. Oct 6, 2011 at 9:46 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    check your belt for cracks first off, that's a sign it's time to replace it. if no cracks on it, it's good to go and you could confidently rule that out as a possibility.
    i hope you're able to find out what the issue is, goodluck !
    cracks would look like this.
  4. Oct 6, 2011 at 9:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    carrier bearing.
    Dust shield over the rotor.
    thats all I got
  5. Oct 6, 2011 at 10:01 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Throwout bearing? Does it stop when you press the clutch in? Otherwise it could be your idler pulley, water pump, power steering. anything that moves could have a bad bearing. Even the alternator.
  6. Oct 6, 2011 at 10:04 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    he has an auto
    OP just noticed you have a large lift and tires. you sure its not a wheel bearing or maybe some suspension joints?
  7. Oct 7, 2011 at 5:32 AM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    If you can put it in neutral and coast with the engine off then it is in the drivetrain. More than likely something is rubbing somewhere.
  8. Oct 7, 2011 at 7:30 AM
    DubVtundy
    Thayer
    how can i see if its the carrier bearing? it does sound like its coming from underneath the truck at some points
  9. Oct 7, 2011 at 7:35 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    crawl under there and see if it has more than like 1/4" of play when you wiggle the drive shaft.
  10. Oct 7, 2011 at 7:39 AM
    DubVtundy
    Thayer
    alright andything else i could possibly look out for?
  11. Oct 7, 2011 at 7:41 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    if its not that I bet its the dust shield that is no the back of the brake rotor.
    Just one question: does it squeel when stopped and the engine idling? or is it only when moving?
  12. Oct 7, 2011 at 7:56 AM
    DubVtundy
    Thayer
    only when moving. its starts about 15 mph and it will do it and the squeal doesnt get a higher tone or anything. its stays at the same tone no matter how fast i am going. but when i slow back down at about 15 mph it dies down and stops.
  13. Oct 7, 2011 at 7:57 AM
    DubVtundy
    Thayer
    also what do you mean about the dust shield?
  14. Oct 7, 2011 at 8:24 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    The dust shield is the stamped steel plate behind the brake rotor. My guess is carrier bearing too unless it sounds a little more like fingernails on a chalkboard. If that is the case, u-joints, but any mechanic should pick that up right away.
    2WD mode right?
  15. Oct 7, 2011 at 8:28 AM
    DubVtundy
    Thayer
    Yes 2wd but still does it in 4wd
  16. Oct 7, 2011 at 8:29 AM
    DubVtundy
    Thayer
    yeah its not u joints we already ruled that one out 2 lol
  17. Oct 7, 2011 at 8:31 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Why couldnt it be a belt at idle? idler bearing/belt slip?
  18. Oct 7, 2011 at 8:43 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    because he said it only does it from 15mph and up.
  19. Oct 7, 2011 at 8:46 AM
    DubVtundy
    Thayer
    Plus I can be moving and put it in neatrul and shut the truck off and drift it and it still does it
  20. Oct 7, 2011 at 9:02 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    check bearings then. even ac compressor spooling down, its bearing.
