sounds like a rattle can
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Jun 12, 2010.
  1. Jun 12, 2010 at 9:57 PM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Whenever I give the gas the right amount pressure it sounds like there is a rattle coming from the passenger side. I'm thinking its coming from the intake. If I give it more or less gas it stops. Anyone had this problem
  2. Jun 12, 2010 at 9:59 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Check for loose bolts inside the glovebox. You will probably have to take it out and tighten all of the bolts.
  3. Jun 12, 2010 at 9:59 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    6speed?
  4. Jun 12, 2010 at 10:23 PM
    NorthernTacoma
    NorthernTacoma Well-Known Member
    Brandon
    Scottsdale, AZ
    10 DC TRD Off-Road 6 speed manual TRD exhaust
    TRD Exhaust, Rear leaf TSB, TRD CAI, Biceman 4x4 Illuminated switch mod
    Holy shit. I've had this problem for the past 3 months. I give a little gas and the rattling comes from the passenger side dash. It sounds like it is coming from underneath it. I've tried to pinpoint the exact source but I can't. I brought it to the dealer and they said there was a tsb out for it. They claimed it was a tag attached to the airbag that caused the rattling. Well, their fix didn't completely solve my problem. The rattle is still there but not as often and not as loud. I do notice it seems to be more prevalent in colder weather.
  5. Jun 13, 2010 at 9:32 AM
    07TaCo07
    oregon
    Auto. I will check the glove box. Did yours sound like it was out side? I was thinking intake was making the noise.
  6. Jun 13, 2010 at 9:43 AM
    NorthernTacoma
    Brandon
    Scottsdale, AZ
    mine definitely sounded like it was coming from the inside. I thought it might have been from installing my cold air intake but I checked my box and it is rock solid and i can't appreciate any noise coming from it.
  7. Jun 13, 2010 at 11:15 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    might there be something clogging the heater core a bit where there could be some cavitation generating? Just a thought....
  8. Jun 13, 2010 at 12:36 PM
    CockoMeaty
    CockoMeaty Member
    Louisville, Kentucky
    10 Pre-Runner
    TSB# 0087-10 should do the trick
  9. Jun 16, 2010 at 12:21 PM
    07TaCo07
    oregon
    I think I fixed it. There was a rock in the intake tube but I think it was the intake rattleing against the fender when it enters it. So I put some rubber hose around the hole and intake fit nice and snuf. Ill drive around in a few and check.
  10. Jun 16, 2010 at 12:22 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Your first post and you're referencing TSBs? Nice! :thumbsup:
    Welcome to TW. :)
  11. Jun 25, 2010 at 12:46 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Open to more ideas. I've had the glove box, front cowl under the windshield, and just about everything else back there ripped off for an inspection. All loose wires zip tied, foam added around the glove box door, etc. Sounds like I have an empty spray can in the glove box.
  12. Jun 25, 2010 at 12:51 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    This ^^ My intake was hitting against my fender making a horrible thud sorta rattle. I put some of that rubber/foam stripping around it and it has never done it again.
  13. Jun 29, 2010 at 8:57 PM
    07TaCo07
    oregon
    So I took the end tube off the intake and drove around and the rattle is still there. I'm thinking it must be the headers or exhaust
  14. Jun 30, 2010 at 9:01 AM
    07TaCo07
    oregon
    What does tsb 0087 fix I can't find it
  15. Jun 30, 2010 at 5:25 PM
    Fortech
    CANADA
    I found my rattle today - it was the poorly made, engineered and fitted windshield cowl. It has never fit correctly since the beginning and Toyota refused to do anything about it. If I shove a glove between the hood and the cowl, all my rattles stop...
