sounds like nuts rattlin in my engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevinboh32, Apr 6, 2009.
  1. Apr 6, 2009 at 3:03 PM
    kevinboh32
    kevinboh32 [OP] Member
    san diego
    07 tacoma 4x4
    K&N intake
    throttling up between 1800 and 2200 RPM's im noticing a noise that sounds like bolts rattling around. I'm becoming a bit concerned about it.
    anyone know what it could be or had a similar issue?
    thanks
  2. Apr 6, 2009 at 3:05 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Where does it sound like its coming from? rear end, front end, engine, interior..etc?
    Oh and welcome to the forum :)
  3. Apr 6, 2009 at 3:06 PM
    kevinboh32
    san diego
    07 tacoma 4x4
    K&N intake
    engine for sure
  4. Apr 6, 2009 at 3:07 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Check your K&N clamps, hoses?
  5. Apr 6, 2009 at 3:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Well...There is the Tacoma Tick...Search for "ticking" and you can read all about it.
    Welcome to the board.
  6. Apr 6, 2009 at 3:11 PM
    kevinboh32
    san diego
    07 tacoma 4x4
    K&N intake
    i have the "tacoma tick" but this is something different.
    a local toyota mechanic mentioned it could be my knocker sensor??
  7. Apr 6, 2009 at 3:13 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    does it do it while the truck is in park, and rpm's up? or only when driving
  8. Apr 6, 2009 at 3:31 PM
    kevinboh32
    san diego
    07 tacoma 4x4
    K&N intake
    only when driving
  9. Apr 6, 2009 at 3:35 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    If it were me, i'd start with the intake. make sure everything is installed properly & secure. don't know about the sensors. your check engine light on?
  10. Apr 6, 2009 at 3:37 PM
    kevinboh32
    san diego
    07 tacoma 4x4
    K&N intake
    just check'ed it all and all is secure and I think installed correctly. light is not on.
  11. Apr 6, 2009 at 3:39 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    any other modifications to the truck?
  12. Apr 6, 2009 at 3:40 PM
    kevinboh32
    san diego
    07 tacoma 4x4
    K&N intake
  13. Apr 6, 2009 at 3:47 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    hmm. other than checking everything under the hood, bolts, brackets, etc.., i dont have any ideas for ya..i'm sure someone smarter will chime in.. :p
  14. Apr 6, 2009 at 4:05 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Check your heat shields on your catalysts, they rust and come apart and rattle when you initially take off, also at the beginning of a gear change. Won't do it while you idle only as you drive. Usually in the lower end of all gears. If they are loose then just pull them off, to get new ones you have to buy the cat.
