Source for buying a new frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by @glass_truck, Oct 3, 2023.
  1. Oct 3, 2023 at 9:44 AM
    @glass_truck
    @glass_truck [OP] Member
    2006 tacoma trd
    5100's, top notch. coils from 2018 trd. Rough country uca's ECGs bushing Carrier bearing drop Diff drop 2" add a leafs
    I’ve tried searching here if anyone has found a source outside of dealerships? Sorry if this has been covered, as all I could find was “ what size size tires can I fit with 3” lift” lol. I missed the recall and I have looked into safety caps and similar options. I would prefer to do the frame swap myself but am having a hard time finding real part numbers etc.
    I’ve found this
    Toyota (51001-04500)
    From Toyota does this fit?
    2015WhiteOR likes this.
  2. Oct 3, 2023 at 9:46 AM
    JDUBZ242
    JDUBZ242 Member
    2nd Gen Taco
    freedom off road UCA, LCA, Rancho Quicklift shock/spring up front, offroad 3" lift shocks in the rear, Hooke front bumper, Freedom-offroad extended swaybar links, Mevotech Supreme inner/outer tie-rod, Supreme Suspension 2" wheel spacers, 285r/75 Thundered tires,
    Smunczen likes this.
  3. Oct 3, 2023 at 9:55 AM
    @glass_truck
    2006 tacoma trd
    I do not, my truck is a 2006, when it was in the warranty period I had it inspected and they said it was not bad enough. Now it certainly is but they won’t help me
  4. Oct 3, 2023 at 10:15 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I got the same treatment. Guy that cleaned and fixed mine said tech's are told not to look very hard for problem. Frame is the costliest of all things, they cost like $3000.00 but it takes something like 70 billable hrs. for labor. So something like $15000.00 in labor, that was the quote I got. Also shipping is going to be crazy.
  5. Oct 3, 2023 at 11:43 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I bought a fairly frame off ebay
    Fun project ahead
  6. Oct 3, 2023 at 12:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    $3,000 frame?
    That is CHEAP……most are $7,000 plus……
    As for the inspection. They are looking for a 10mm hole.
    They will NOT peck, pry, push or pick at the frame. All they do is LOOK at it.
    If all that’s there is a paper thin piece of rust, but no hole. It passes.
    But, most reputable shops will “make it fail” if it’s that bad.
    Doesn’t make any difference to OP. His truck is long out of warranty.
    If it’s just one or 2 spots on the frame. A patch plate would be cheaper.
    But if it’s pretty much the whole frame, then a new frame is the only option.
    Well, other than parting it out and buying a new truck.
    Ricardo13x and Tiedie[QUOTED] like this.
  7. Oct 3, 2023 at 12:02 PM
    Clearwater Bill
    Billy
    Largo Florida
  8. Oct 3, 2023 at 12:12 PM
    Tiedie
    David
    WFOY
    Oh yeah that is what my guy said. He used to work for Dodge and Toyota. Back years ago Dodge had a recall on drive shafts and they gave tech. a spring loaded punch to test but it was alloy. So hardened steel vs. Alloy which one dented first?
    His words not mine.
    TnShooter[QUOTED] likes this.
  9. Oct 3, 2023 at 12:20 PM
    @glass_truck
    2006 tacoma trd
    So the available frame turns out to not fit and the the direct fit frame is unavailable, I don’t think it’s beyond repair with safety caps. I wish I could just buy a new one
  10. Oct 3, 2023 at 12:22 PM
    @glass_truck
    2006 tacoma trd
    Found a 2021 double cab frame for 1500. Anyone have an idea on how hard it would be to make this work? 2006 access cab. How different are they
  11. Oct 3, 2023 at 2:34 PM
    TnShooter
    Deogee
    STOCK
  12. Oct 3, 2023 at 2:46 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    If I needed a new frame, I would look at part outs, or at junk yards. Surely someone has a unbent frame that they just need to get rid of
  13. Oct 3, 2023 at 3:06 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Frames from salvage yards if you can find one that will sell just the frame are about $3,500 on up,and you have too pull all the parts off it,cab,engine,axles,etc.
  14. Oct 3, 2023 at 3:14 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
  15. Oct 5, 2023 at 5:44 AM
    jwarr
    jwarr Well-Known Member
  16. Oct 5, 2023 at 2:37 PM
    farmerfromkansas
    farmerfromkansas Active Member
    2014 regular cab base truck
    Why not check with Keystone LKQ. My friend in the car business picks up parts in Wichita from them, free shipping.
  17. Oct 11, 2023 at 8:05 PM
    Fzfg1000
    Fzfg1000 Well-Known Member
    I have a similar problem. I bought a new truck. Definitely not worth the hassle and if the frame is rusting who knows what else is. Brake lines rust too...
