source for replacement drive shaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by piratedude, May 20, 2019.
  1. May 20, 2019 at 6:08 PM
    piratedude
    piratedude [OP] Member
    2008 crew cab prerunner trd
    i know there are driveshaft threads, but my searched turned up nothing on topic.
    2008 double cab 4 liter auto. i changed front and rear u joints two years ago, and noted that the front yoke u joint holes were damaged pretty badly. new u joint squeak just appeared, so i assume it is the center joint. also, vibration on acceleration, so assume it is the center bearing.
    i cannot locate a front yoke at any parts house or Toyota, so am considering an entire new driveshaft assembly. dealer says $800. any suggestions?
    tia
  2. May 21, 2019 at 6:06 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Junkyard?
  3. May 21, 2019 at 6:18 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    i have mine listed with new joints and cb, 4x4 shaft tho. Prerunner shafts are a bit different
    junkyard is your next best bet, aftermarket shafts arent cheap these days with the rise in materials
  4. May 22, 2019 at 3:16 AM
    piratedude
