Source for steel wheels
Discussion in 'Wheels & Tires' started by Meyer73cj5, Jan 12, 2021.
  1. Jan 12, 2021 at 11:28 AM
    Meyer73cj5
    Meyer73cj5 [OP] New Member
    2010 Tacoma
    All,
    New here, been on numerous forums, thank you for letting me in!
    I have a 2010 Tacoma 4x4, live in Indy, and will be moving to Phoenix. Trying to get it setup for light trail use. Going with the 3" OME lift/dakar/885 setup from toytec. Also going to run 285/75/16 tires. I will trim or cut whatever is needed.
    I am searching for steel wheel options, specifically 16".
    Procomp sells them but in talking to them they will rub the calipers, to the extent they will not work (ie, grinding calipers not enough).
    I have seen links through searching to the RoadReady wheels - 16x7 that are supposed to fit 2005-2020 Tacomas. I am not sure the backspacing on those, but I assume they would clear the calipers.
    Does anyone know another source? I have searched but likely using the wrong terms.
    Thanks
    Scott
