South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Feb 17, 2016 at 7:02 AM
    #5221
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Also.. studs are cheap... and pretty simple to replace..
    TownvilleTim and ahspurlock[OP] like this.
  2. Feb 17, 2016 at 7:02 AM
    #5222
    SoutheastOverland
    SoutheastOverland Lost in the Woods
    Seneca, SC
    2007 FJ Cruiser
    Metal-Tech sliders, front and rear bumpers, Warn M8000 winch with Southeast Overland Amsteel Blue winch line, Mombasa RTT and awning, BajaRack Expo Rack, Hella lights, custom storage, PowerTank
    I used blue loctite and a torque wrench on your spacers they should come right off, they are only torqued to 100 Ft LBS. Could anyone else have messed with them?
    With that being said a map gas torch and about 10 seconds on the lug will heat up the loctite enough to take the nut off without worrying about it.
    ~Jeff
  3. Feb 17, 2016 at 7:03 AM
    #5223
    Mothman
    Advance
    single cab
    This... no need to heat it til it's glowing.
    scottalot and ahspurlock[OP] like this.
  4. Feb 17, 2016 at 7:04 AM
    #5224
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Fuck yeah. I saw some red shit on the studs so I thought it was red loctite. My bad. So what is needed to get them off? Can a tire shop do it without breaking them? I tried an I can't budge them
    ahspurlock[OP] likes this.
  5. Feb 17, 2016 at 7:07 AM
    #5225
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Nope they haven't been messed with at all
  6. Feb 17, 2016 at 7:10 AM
    #5226
    SoutheastOverland
    Seneca, SC
    2007 FJ Cruiser
    No biggie, Unless someone has red loctited it an impact should take it right off. Id venture to say a tire shop would be able to get it off. But beware, many tire shop people do not care about damaging your truck.
    ~Jeff
  7. Feb 17, 2016 at 7:11 AM
    #5227
    SoutheastOverland
    Seneca, SC
    2007 FJ Cruiser
    If they really wont come off. Bring it up here and I will pull them for you free of charge.
    ~Jeff
  8. Feb 17, 2016 at 7:12 AM
    #5228
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    a few of mine are fairly well rounded off thanks to the damn shop. im not looking forward to having to take the wheels off anytime soon.
  9. Feb 17, 2016 at 7:12 AM
    #5229
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ok cool thanks. I've been using a pipe over the handle of a ratchet to get the wheels off. That's what I tried to take the stud bolts off with which failed. What tools are needed so I can do this at home today? I'll see if O'REILEYS can loan the tools
  10. Feb 17, 2016 at 7:14 AM
    #5230
    Mothman
    Advance
    single cab
    Just put a little ass on them.. I'm a huge fan of standing on a breaker bar.
  11. Feb 17, 2016 at 7:15 AM
    #5231
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Sweet I'll see if I can get them off. What tools are needed? I'm trying to learn as I go. Also to keep the front from rotating when wheels is off do I just need to get my wife to hold the brake in?
    @SoutheastOverland
  12. Feb 17, 2016 at 7:18 AM
    #5232
    SoutheastOverland
    Seneca, SC
    2007 FJ Cruiser
    I would use a 3 ft. breaker bar with the correct socket (21mm? If I remember correctly). A map gas torch can be had at Home Depot or Lowes, for less than $30. Id recommend just buying the stuff so you have it again if you ever have to take them back off.
    ~Jeff
  13. Feb 17, 2016 at 7:20 AM
    #5233
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ok cool I'm not planning to put spacers back on...
  14. Feb 17, 2016 at 7:22 AM
    #5234
    SoutheastOverland
    Seneca, SC
    2007 FJ Cruiser
    That works, the torch and breaker bar is a helpful thing to have while working on a truck. The magic trio for stuck bolts out is breaker bar, torch and PB Blaster. LOL
    ~Jeff
  15. Feb 17, 2016 at 7:28 AM
    #5235
    Mothman
    Advance
    single cab
    Put it in 4x4
  16. Feb 17, 2016 at 7:35 AM
    #5236
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    :annoyed:Why didn't I think of that
  17. Feb 17, 2016 at 7:35 AM
    #5237
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    Ideas are happening
    ahspurlock[OP] and Mothman like this.
  18. Feb 17, 2016 at 7:51 AM
    #5238
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    me too but interresting tho
    scottalot[QUOTED] likes this.
  19. Feb 17, 2016 at 7:56 AM
    #5239
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Still need to apply the brake?
  20. Feb 17, 2016 at 8:06 AM
    #5240
    Mothman
    Advance
    single cab
    If so slide a big screw driver into the slot on the brake rotor and let that rotate into the caliper.. I always just use the front locker..
