South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Dec 22, 2016 at 3:53 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    I think I remember he talked to Vin at SCS about the next run of F5's....wondering what he said.
  2. Dec 22, 2016 at 3:53 AM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    :yes:
  3. Dec 22, 2016 at 3:53 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    yea i think he did
    scottalot and ChadsPride[QUOTED] like this.
  4. Dec 22, 2016 at 3:54 AM
    ChadsPride
    Wanting to pick his brain a little today...Its like SCS is sold out of every wheel that will work property with my setup.
    :help:
  5. Dec 22, 2016 at 3:55 AM
    ahspurlock
    Adam
    what wheel setup you need
  6. Dec 22, 2016 at 3:55 AM
    ChadsPride
    Need a 17x9 with 4.5 bs or less
    because_wumbo-truck likes this.
  7. Dec 22, 2016 at 3:58 AM
    ahspurlock
    Adam
    ok so the same as mine . im running 5 17x9 with 4.25BS but mine are procomp 7005
  8. Dec 22, 2016 at 3:59 AM
    ChadsPride
    Those look good! You are running Maxtracs also?
  9. Dec 22, 2016 at 4:00 AM
    ahspurlock
    Adam
    but if you want them to stick out some you will need a BS of 3.5 or run spacers like a 1.25
    scottalot and ChadsPride like this.
  10. Dec 22, 2016 at 4:00 AM
    ahspurlock
    Adam
    i was till i converted to 4wd
  11. Dec 22, 2016 at 4:01 AM
    ChadsPride
    For sure, The F5's I want have 3.5 bs
    Bad Ass!!!
  12. Dec 22, 2016 at 4:02 AM
    ahspurlock
    Adam
    this is what 4.25 BS looks like on maxtracs
  13. Dec 22, 2016 at 4:02 AM
    ChadsPride
    That a 9" wide wheel?
  14. Dec 22, 2016 at 4:03 AM
    ahspurlock
    Adam
    you will still need a spcer for the rear to macth the front i was running a 1.25 spacer on the rear to match the front
    ChadsPride[QUOTED] likes this.
  15. Dec 22, 2016 at 4:04 AM
    ahspurlock
    Adam
    yep 17x9 on maxtraces
  16. Dec 22, 2016 at 4:04 AM
    ChadsPride
    Yeah, Im running the 1.25" wheel spacers out back right now. Just wanting a wheel that i can use and take those suckers off totally
  17. Dec 22, 2016 at 4:05 AM
    ahspurlock
    Adam
    if your running maxtracs that wont happen unless you buy 2 diff BS rims
  18. Dec 22, 2016 at 4:06 AM
    ChadsPride
    Right, I dont mind having a the front stick out more than the rears really...
  19. Dec 22, 2016 at 4:06 AM
    ahspurlock
    Adam
    im still running my rear spacers
    ChadsPride likes this.
  20. Dec 22, 2016 at 4:06 AM
    ahspurlock
    Adam
    oh ok then you should be good
