South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Feb 23, 2016 at 5:11 PM
    #6161
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I am going to see sandman this weekend to help me wire em up. I have one of his blocks waiting for me when i get there :thumbsup: I got one of these switch panels for the in cab switch. Have one more switch now for ditch lights
    scottalot[QUOTED] likes this.
  2. Feb 23, 2016 at 5:15 PM
    #6162
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    10-4 to that. I had none cuz the seat heaters
  3. Feb 23, 2016 at 5:19 PM
    #6163
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Seat heaters?! :ohsnap:
    SC2SC and JimboAnz[QUOTED] like this.
  4. Feb 23, 2016 at 5:21 PM
    #6164
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Lol, heck yeah. Come in real handy on those really cold mornins.
    SC2SC likes this.
  5. Feb 23, 2016 at 5:21 PM
    #6165
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    @scottalot You decided to keep your CBI ditch light brackets? I've got a set myself that still needs to be installed and I haven't chopped on anything yet.
    scottalot likes this.
  6. Feb 23, 2016 at 5:23 PM
    #6166
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    I bet! Previous owner of my truck had a remote start installed because he lived up in MA. Comes in real handy down here in the mornings when it's in the 50s.
    :rofl:
    SC2SC, JimboAnz[QUOTED] and scottalot like this.
  7. Feb 23, 2016 at 5:23 PM
    #6167
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I will probably try the SDHQ boots for my CV's.
    Just trying to figure out what kind of grease to use and how much.
    Anybody know the answers? There is not much info out there about the grease.
  8. Feb 23, 2016 at 5:24 PM
    #6168
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    O'Reilly sells CV axle grease, that's what I used last.
  9. Feb 23, 2016 at 5:26 PM
    #6169
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Sounds good then! Would've traded you cowls to save you the $250.
  10. Feb 23, 2016 at 5:26 PM
    #6170
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I want one of those too :thumbsup:. We had many a morning in the 20's this year, i hate being cold.
  11. Feb 23, 2016 at 5:32 PM
    #6171
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Just found a pretty good explanation on YOTATECH
    (This is not mine, it is a copy/paste from YOTATECH. There were some pictures as well but they didn't transfer on my iPotato)
    I'm pretty sure the theory behind using "yellow" grease for the inner joint and "black" grease for the outer joint is because of the difference in bearing design. The inner(tripod) joint uses anti-friction bearings(pin rollers in cylindrical races) and semi-friction bearings(outer races in tripod housing). And the outer(birfield) joint uses semi-friction bearings(balls in deep groove races).
    So what's the difference between "yellow" and "black" grease, and/or how does it apply?
    Typically, "black" grease is a Moly/Graph(Molybdenum/Graphite) fortified EP(Extreme Pressure) grease. Which isn't necessarily "black", but usually more of a medium to dark grey. And may contain just moly, graph, or both. But in general "black" grease is "Moly" grease(since molybdenum disulfide is black). It's generally best suited for friction(or semi-friction) type bearings. But can be used as a MP(Multi-Purpose) grease.
    "Yellow" grease is, typically, a High-Temp EP Disc Brake Wheel Bearing grease. Which isn't always "yellow"(and can in fact be any color, but is usually a color and almost never "black", grey, or white, and not all "yellow" grease is suited for disc brake wheel bearings). It may also have Moly("red moly" not molybdenum disulfide) in it, but generally not Graph. It's almost always tackier, and good to significantly higher temperatures, than typical "black"(Moly/Graph) grease. And is best suited for disc brake wheel bearings specifically, and any EP anti-friction bearings in general. But it can also be used as a MP grease.
    So, you can use pretty much any EP grease for either type of CV joint if you wanted to. Or just use one type for both(see below). It's not bound to make that much difference. It's all good grease for CVs, if it's EP grease...IMO. You'll also find that just about any(if not all) EP grease says it can be used for CV joints on the label, regardless of color(and/or constituents).
    SC2SC and scottalot like this.
  12. Feb 23, 2016 at 5:37 PM
    #6172
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I know the stuff in the factory boot kit is yellowish, and somewhat "runny" (much more so than what you would put in your u-joints for example).
  13. Feb 23, 2016 at 5:47 PM
    #6173
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
  14. Feb 23, 2016 at 5:57 PM
    #6174
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    You never know what you will read in an Amazon review.
  15. Feb 23, 2016 at 6:03 PM
    #6175
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    "Maroon colored bag of agony" :rofl:
  16. Feb 23, 2016 at 6:09 PM
    #6176
    Irongrave
    Irongrave Well-Known Member
    Drew
    Knoxville TN
    1998 T4R Limited
    Finally home and enjoying a nice fat tire damn it was a long day.
    dan0mite and SC2SC like this.
  17. Feb 23, 2016 at 6:25 PM
    #6177
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    That is some awesome grease!
    Connormc11 likes this.
  18. Feb 23, 2016 at 6:39 PM
    #6178
    SC2SC
    Jonathan
    South of Charlotte
    Ummm... How did you find that...!?! o_O
    Did you find what you were looking for, lol!!! :rofl:
  19. Feb 23, 2016 at 7:04 PM
    #6179
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I used Lucas Red N Tacky on mine. That's my answer to most grease questions
    TownvilleTim likes this.
  20. Feb 23, 2016 at 10:47 PM
    #6180
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Ok.....so I'll ask. Why is there what looks to be a huge rock next to your cooler?
