South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. May 8, 2018 at 3:59 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    Yep going back to old school hahaha. Plus side is it runs and drives . Has a 22re and a 5speed manual trans . Thinking about bagging it or hydro
    Matic likes this.
  2. May 8, 2018 at 4:00 AM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Those poor El Caminos...:(
  3. May 8, 2018 at 4:00 AM
    ahspurlock
    Adam
    I know right it's a shame
    dan0mite[QUOTED] likes this.
  4. May 8, 2018 at 4:02 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I hope not. I just replaced them ~4K miles ago
  5. May 8, 2018 at 4:04 AM
    ahspurlock
    Adam
    Ok .
    What kind of miles are on it ?
    May also want to try and clean the mass air flow sensor . I clean mine about every 10,000 miles
    scottalot and ovrlndkull like this.
  6. May 8, 2018 at 4:05 AM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    :rofl:
    scottalot, Marty65 and ahspurlock[OP] like this.
  7. May 8, 2018 at 4:05 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Just turned 135k yesterday. I cleaned the MAF at the same time I did the plugs.
  8. May 8, 2018 at 4:10 AM
    ahspurlock
    Adam
    Ok gotcha . Have you done a fuel system cleaner/treatment yet . I do that every 30,000 miles I run it trouthr the intake and cleans all the carbon out and the valves but you'll have to take it somewhere for that unless you have the drip bottle to do it with. Also on a side note I've noticed some gas lately has been causing somes of these issues
  9. May 8, 2018 at 4:14 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I have not done the fuel treatment. Do dealerships do it? I’m taking it in to get some stuff done and if they do, I’ll just get them to do it.
    scottalot likes this.
  10. May 8, 2018 at 4:14 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
  11. May 8, 2018 at 4:14 AM
    ahspurlock
    Adam
    Yes they do or at least they're supposed to
  12. May 8, 2018 at 4:15 AM
    ahspurlock
    Adam
  13. May 8, 2018 at 4:17 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Y’all the bomb :thumbsup:
  14. May 8, 2018 at 4:19 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I dont even know where my MAF is or what it looks like. :anonymous: I will hunt that bitch down this weekend when doing 110K oil change
    scottalot, Daria and saundern like this.
  15. May 8, 2018 at 4:21 AM
    ahspurlock
    Adam
    Just text you lol
    scottalot and JimboAnz[QUOTED] like this.
  16. May 8, 2018 at 4:23 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    :bowdown: Thank you Sir
  17. May 8, 2018 at 4:35 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    In the intake duct before the throttle body. There are 2 sensors the IAT and MAF in it. The actual MAF is up a little tube when you pull it out the visible part that looks like a dangling bulb is the IAT so clean both. I usually use MAF sensor cleaner or and electrical cleaner. It's not as harsh as Carb/throttle body cleaner but that works also.
    Do the simple things first like @ahspurlock and @JimboAnz suggested. Even though you just changed your plugs its a good idea to pull them and check the coil pack boots and plugs to see if there are any traces of missfire, cracked porcelain, etc.
    Vacuum leak, air intake leak after the MAF all can cause rough run as well. Unmonitored air going to the engine. Also if your air filter is extremely dirty or that secondary air filter if those haven't been changed and are slap full of dust and debris. I took the secondary air filter out of my truck.
  18. May 8, 2018 at 4:36 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Where was the invite?!?! :(
  19. May 8, 2018 at 4:45 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    This^^^^^ if you suck seafoam or similar too fast into the engine and it hydrolocks not good go slow and take your time. That's why Adam suggested a drip bottle it's easier to control and goes at a steady rate. Seafoam has some good directions on their can. But be prepared for it to run rough for a little while and smoke like crazy for a little bit. You are essentially flooding the engine.
    I've gotten some gas lately that caused low gas mileage and felt a little down on power I think their water separators needed to be changed and I got some with excessive water in the fuel sucks!!!
    scottalot and JimboAnz like this.
  20. May 8, 2018 at 4:46 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    maybe there is 2 (or more) kinds of seafoam, the one I use I dump into a full tank of gas........
